3 inch drop
Discussion in 'Street Trucks' started by jason smith, Feb 7, 2011.
  1. Feb 7, 2011 at 7:08 PM
    jason smith
    jason smith [OP] loblk08taco
    Tennessee
    08 sr5 2wd 5sp 2.7
    flowmaster 40 series orig flo, cold air intake,painted headlights.Trex eyelids, xrunner wheels, street tacos 3"drop rear, djm 3" drop front
    I have a 08 access cab 5 lug,im going to use the djm 3 inch drop on the front.On the back im looking at 3 inch blocks from street tacos,the problem is I dont know if i need the tapered or non tapered blocks.It says if you use the stock springs i have to use offset pins,but i dont know about the taper they are available both ways:confused:
  2. Feb 7, 2011 at 7:15 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Send brian an email or pm on here. He goes by beefed taco
  3. Feb 7, 2011 at 10:00 PM
    pinktaco808
    pinktaco808 Hot Steppa
  4. Feb 8, 2011 at 7:13 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    you would probably be fine with straight blocks, the tapered blocks are more for lifts to get the drive shaft angle right.. and Im not sure about the base model trucks but on my x runner for a 3 inch drop you have to notch the frame.
  5. Feb 8, 2011 at 7:39 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    you really only need tapered blocks when they hit 4". Straight blocks will be fine
  6. Feb 9, 2011 at 10:07 PM
    pinktaco808
    bestest blocks ever
  7. Feb 9, 2011 at 11:42 PM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    Dropped trucks have to deal with drive shaft angles, carrier bearings, etc., the concept is the same we still have live axles that you are either moving away or closer to the frame.
    and you can go up to 4" out back without notching on the regular 5 lugs, its just your axle will be sitting very close to the frame. I'm at a 3.75" out back currently.
    Angled blocks usually for anything more than 3"
