3" inch leveling lift suggestion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wpxjacampos, Jun 24, 2016.
  1. Jun 24, 2016 at 7:11 PM
    Wpxjacampos
    Wpxjacampos [OP] Active Member
    jesus
    Toyota tacoma 1995 2.4L
    Group i receive from the suspension suplier a 3" front and 2" rear leveling kit.
    1 1/4" front spacer and a 2" rear spacer is this correct??
    I ask for a 3" front and 2" rear leveling kit and i got this!!
    I dont know how they do the calculation for the lift can someone help?
  2. Jun 24, 2016 at 7:19 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Roughly double the front spacer thickness to determine the resultant front lift. It is not a 1 to 1 ratio.
  3. Jun 24, 2016 at 7:23 PM
    Wpxjacampos
    jesus
    So if it 1 1/4 so it will be 2.5" total lift??
  4. Jun 24, 2016 at 7:28 PM
    mutilatedjak
    WA
    Yup. Approximately.
  5. Jun 24, 2016 at 7:33 PM
    Wpxjacampos
    jesus
    Ok thanks
  6. Jun 24, 2016 at 7:41 PM
    Pigpen
    Dan
    Northwest Montana
    Or you could do it properly...
  7. Jun 24, 2016 at 7:44 PM
    Wpxjacampos
    jesus
  8. Jun 24, 2016 at 7:51 PM
    Wpxjacampos
    jesus
    Since this is not a 1 to 1 ratio; my front spacer is 1 1/4 " since i been advice that double the spacer thickness will be the total heigth of the lift.
    My rear spacer is a 2" block
    I ask for a 3 " front lift and a 2" rear lift
  9. Jun 24, 2016 at 7:53 PM
    Wpxjacampos
    jesus
    I dont use the truck for offroad i barely used it and i will like to have a level truck
  10. Jun 24, 2016 at 8:00 PM
    Pigpen
    Dan
    Northwest Montana
    I sent a PM
    Even on road, you can break your struts with too much spacer lift. I don't know how much is okay and what's too much. The key is that you only have so much travel available on stock components. When you lift, you use up what would be down travel. When you lift with a spacer, you need to lengthen your bump stops so that the strut doesn't bottom out - which can cause it to break.
  11. Jun 24, 2016 at 8:07 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I personally think the spacer thing is a myth but you could buy bilstein 5100's for the front. They are adjustable shocks with .85 1.75 and 2.5 settings. I would suggest an aal for the rear to minimize axle warp.
  12. Jun 24, 2016 at 8:09 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
  13. Jun 24, 2016 at 8:14 PM
    Wpxjacampos
    jesus
    Thanks for the information.
    But my big question is to be shure the 1 1/4 " front spacer will level my truck with the 2" blocks at the rear
  14. Jun 24, 2016 at 8:22 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    You should be pretty close. The front spacer should yield 2.5 inches of lift. Measure from the hub to the bottom of the fender and do the math.
  15. Jun 24, 2016 at 8:41 PM
    Wpxjacampos
    jesus
    But from the supplier i ask for a 3" front and 2" rear does mean they send me the wrong kit?
  16. Jun 24, 2016 at 8:44 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Usually the front spacer lifts double the height of the spacer.
  17. Jun 24, 2016 at 8:52 PM
    Pigpen
    Dan
    Northwest Montana
    Kyitty and mutilatedjak like this.
  18. Jun 24, 2016 at 10:04 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
  19. Jun 25, 2016 at 4:57 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Well there you have it myth busted. OP get the spacers and make sure you get taller bumpstops.
