3 inch lift 285's????????????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by countryboy22, Oct 8, 2009.
  1. Oct 8, 2009 at 2:11 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    nah i was just makin it flex that isnt REAL offroading at all its a pile of clay outside of a house that i do yard work for
  2. Oct 8, 2009 at 2:12 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Do wheel spacers make you rub more on the top of the fender?
    I understand how they get you away from the uca but under full flex it seems that usually the tires stuff up in the fender and spacers would make the top of the tire rub on the fender...?
    What about stock rims, 3in lift, total chaos ucas and 33in tires, any rubbing issues there?
  3. Oct 8, 2009 at 2:19 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I do not believe they make you rub any more or less on the top of the fender. And I have the a 3" lift, TC UCA's, 285/75/16's, and the 1.25" spidertrax spacers. If you dont run the wheel spacers you will more than likely rub the uca and definitely rub the fenders when you turn. Even with the spacers you have to slightly trim some fender. Nothing noticeable though. But at least you will be free from the uca. With a 3" lift up front and about a 1.5" lift in the rear you should be clear from the top of the fenders.
  4. Oct 8, 2009 at 2:21 PM
    wilsonpj
    Pete
    2006 DC, SB, OR
    okay, i thought that you did not need spacers if you have some uca's like tc.
  5. Oct 8, 2009 at 2:25 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Aftermarket uca's like TC or camburg or light racing will help correct you alignment after the lift. They also give you a little more travel.
  6. Oct 8, 2009 at 3:15 PM
    countryboy22
    countryboy22 [OP] Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    am i going to have allignment issues with this lift
  7. Oct 8, 2009 at 4:02 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    from 2" to 3.5", the higher you go up from 2", the less able you will be able to to get it back to stock. Lots of people run a 2.5" lift without new uca's. But if you want to get your alignment back to factory you should buy the uca's. They also perform much better too.
  8. Oct 13, 2009 at 7:22 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    I here ya JDKeller, I cannot beleive he doesn't rub hard on the uca's,
    I have a 2.5 lift with 285\75\16's and I also have the 1\4 spacers and I rub hard enough to raise the truck when I turn all the way and hit uca's, not only that I just don't feel comfordable with these spacers, I have the spidertrax spacers on the way...
  9. Oct 13, 2009 at 7:25 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    ok ok ill help solve this debate. i had 285's on stock wheels, it rubbed on the uca but no rubbing anywhere else. i did get a 1/4" spacer to push the wheels away from the uca but remember you are also losing a 1/4" of thread on your lugs, i was not too comfortable with this so i just bought aftermarket wheels.
    either get the 1/4" spacer and just check your lug nuts with a torque wrench every now and then or get spidertrax spacers.
  10. Oct 13, 2009 at 7:29 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Thats what i'm running, 3" toytec ultimate lift, tc uca's , 285/75/16 and i had to trim some fender but i'm still nailing the body mount...I have the fj trd wheels which are .5 wider than stock. Will the 1.25" spiders fix the rubbing on the body mount ? - or is the only real way to fix that to cut up and weld the body mount?
  11. Oct 13, 2009 at 7:30 PM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    Damn I ran 3" lift with 285/70/17s on stock sport rims. The only rubbing I got was at full crank on the UCAs. I have No wheel spacers and stock UCAs. I beat the shit out of her as often as I can. I have not had one single issue. I had it this way for 3.5 years. I just barely got new wheels and tires.
  12. Oct 13, 2009 at 7:38 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I have the spidertrax and still SLIGHTLY rub the bod mounts. Not enough to make me do the body mount chop mod.
  13. Oct 13, 2009 at 7:38 PM
    Razorecko
    ^ what lift kit are you running ?
  14. Oct 13, 2009 at 7:45 PM
    imsikotic
    Randy
    Temecula, Ca
    Just a toytec 3" spacer
  15. Oct 13, 2009 at 7:51 PM
    #35
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    ive got a 3" lift and 285-65X18 and the only rubbing i get is on the cab mounts while flexing and turning at the same time.
  16. Oct 13, 2009 at 7:54 PM
    #36
    Razorecko
    Same, its when i'm going up or down a driveway thats on an incline
  17. Oct 14, 2009 at 2:56 AM
    #37
    Reaper22
    Palmyra Missouri
    SR5 Tacoma
    It's gotta be the different makes of tires to where they will rub, Like I said if I turn all the way to the right you see the left front side of the truck rise quite a bit, and the paint is worn off the front sides of the uca's.. Not sure where else it will rub yet, don't want to off road till I get the spidertrax..
  18. Oct 14, 2009 at 8:36 AM
    #38
    Razorecko
    I have the tc uca's and they are fine. Seems like the only time you'll rub your uca is if its the stock one.
  19. Oct 15, 2009 at 10:44 PM
    #39
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    Do you guys run the spacers in the back as well? If not can you notice the front wheels having more poke than the back??
  20. Oct 16, 2009 at 12:37 AM
    #40
    jdkeller
    Jonathan
    Inland Empire, Ca
    Most people including me run them in the rear as well. Mostly just to make it look even because you will notice. However, its not that big of a difference. If you want, just get the front and put them on. If you want the back, them order another set.
