3 inch lift and mileage afterwards
Discussion in 'Suspension' started by AK27, Apr 3, 2009.
  1. Apr 3, 2009 at 9:25 AM
    AK27
    AK27 [OP] Well-Known Member
    hey guys and gals,
    just wondering about how much a 3 inch lift affects fuel mileage? please let me know which lift set up you have also:)
    thanks!
    AK
  2. Apr 3, 2009 at 9:36 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I have the Bilstein 5100s at 2.5 (close enough :eek:) and I have noticed about a 1 to 2 MPG drop. (I have BFG A/T's as well, which are pretty heavy.)
  3. Apr 3, 2009 at 9:37 AM
    AK27
    excellent, good to know:)
  4. Apr 3, 2009 at 9:38 AM
    Pro60
    Pro60 Well-Known Member
    Thomas
    Pensacola, Florida
    Lifted 08 TRD OFFROAD
    3" Skyjacker suspension lift, MO951b 18x9, 285/65/18 Nitto Terra Grapplers, Total Chaos UCAs, TRD Seat covers, Weathertech floormats, UWS LP toolbox, mudflap delete, seatbelt chime off, foglight mod, K&N Drop in filter,double limo tint, hose clamp mod, blacked out badges, rear diff breather mod
    Im getting 18.5 around town while driving easy. My setup is a skyjacker 3" susp lift w/ 33" terra grapplers 10 ply.... hope this helps :)
  5. Apr 3, 2009 at 7:21 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    actually the lift will not change the milage.its the tires u chose.
  6. Apr 3, 2009 at 9:28 PM
    das56170
    das56170 Well-Known Member
    Orange County
    2007 Tacoma Access Cab 4X4 SR5 (sold), 2002 Tundra Access Cab 4x4 SR5, TRD Offoad
    Tacoma - Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    also keep in mind that larger tires are going to throw off your speedometer which will mess up your calculations. Hypertech makes a product that corrects this though.
  7. Apr 3, 2009 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    After correction for tire size, and with 91 octain fuel, my last take was 20.58 mpg. mixed city and highway.
  8. Apr 3, 2009 at 9:36 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Toytec 3" lift with BFG ATs 33" actually measures 32.6"
    Just made a 400 mile trip averaged 21mpg. according to scanguage and 20.8 according to my calc.
  9. Apr 3, 2009 at 10:16 PM
    BiggWooD
    BiggWooD Well-Known Member
    Opp, Alabama
    Tacoma
    Pro Comp Leveling Kit 17" RBP Wheels 33x12.50 Wild Country RVTs
    Lift will change mpg as it increases more air flow under the truck and more resistance.. Not trying to call you out just helping man ;)
  10. Apr 4, 2009 at 6:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add, it increases the frontal area of the vehicle. AND if used with larger tires, increased rolling resistance, and rotational mass. :)
  11. Apr 4, 2009 at 8:25 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    huh i have a hard time understanding that.u didnt add mass to your truck with the lift.weather your stock or lifted its still the same front end as far as wind drag.and i still got the same milage with my lift and stock tires.just put 265s on so that im sure will change the milage a bit.
  12. Apr 4, 2009 at 8:28 AM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    i had no change when i put my C/Os on but once i put my tires on there was a big loss :(
  13. Apr 4, 2009 at 2:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Rotational mass. If the tires are larger in diameter, Rotational mass increases.
  14. Apr 4, 2009 at 2:43 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have 5100's all around with 885's up front, rear AAL's, and 18"s on 33"s. My MPG on the street= "Don't Care.":D MPG on the highway= "Don't care cause the truck looks sick!";)
  15. Apr 4, 2009 at 3:06 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    with that said,the lift doesnt change the mpg,the tires do.
  16. Apr 4, 2009 at 3:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Part true...The increased sail area from the also lowers MPG.
  17. Apr 4, 2009 at 3:14 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    ok,i just no my mpgs did NOT change with just the lift.no argument here.all done.
  18. Apr 4, 2009 at 5:16 PM
    AK27
    thanks for the info everyone!
