3 inch lift and/or leveling kit pics thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by napiliboy47, Feb 8, 2010.
  1. Jun 15, 2016 at 4:39 PM
    #381
    hmasonb34
    hmasonb34 Well-Known Member
    Heath
    Jax, Fl.
    98, ext cab and 2015 LB dbl cab 4x4 sport
    My 98 has 4 in.beefed blocks, QA1 up front, turbo. My 15 4x4 stock looking for lift and tires.
    Hey bud ive got the same rims on my 2015 dclb sport. Im looking to do the toytec 3 inch lift. I also would be interested in what you had to do to fit those big meats under there. I also plan on running 33/12.50/17s after i get my lift. Im wanting something geared to soft sand ridding. How do those tires do in the soft sand.
  2. Jun 15, 2016 at 5:39 PM
    #382
    09YotaArk
    09YotaArk Active Member
    Blake
    2009 Tacoma 4x4
    3" Rough Country 33" x 12.5" Mickey Thompson MTZ
    All I had to do was trim about a half inch off of my fender flare and trim my splash guard a little bit but other than that it hasn't rubbed one bit
    hmasonb34 likes this.
  3. Jun 15, 2016 at 5:42 PM
    #383
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    cool thanks i've already removed my mudmflaps and was panning on a little trimming of the flare so that sounds perfect
  4. Jun 15, 2016 at 5:42 PM
    #384
    09YotaArk
    Blake
    2009 Tacoma 4x4
    I didn't have to do any major trimming at all. I just had to cut a little off of the lip on the bottom of the fender flare and trim my splash guard. I'm from Arkansas so I honestly couldn't tell you how they do in the sand haha but in snow and mud they have been the best tire I have had
    hmasonb34[QUOTED] likes this.
  5. Aug 6, 2016 at 6:06 PM
    #385
    Jgchfd
    Jgchfd Well-Known Member
    James
    Kentucky
    2016 Tacoma SR5 DCSB
    What type of rubber?
    NeedmoreTaco likes this.
  6. Aug 6, 2016 at 6:09 PM
    #386
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
  7. Feb 17, 2017 at 8:51 PM
    #387
    Johnkkaw
    Johnkkaw Active Member
    13 Tacoma off road
    3 inch lift roof racks smittybilt awning. Yakima ski clamps led headlights and fog lights. Led reverse lights and rigid aux reverse lights. Smittybilt built 95k winch and rigid 30 inch bar in grille. Alpine type r sub in spec box behind rear seat. Power pack amp pass through wire to factory deck
    Awsome looking truck I want to get a color matching camper 4 mine too but it's so expensive here in Hawaii
  8. Feb 17, 2017 at 9:42 PM
    #388
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Is that white or cement?
  9. Feb 17, 2017 at 9:43 PM
    #389
    ecotecin
    WV
    3 inch bilstein kit with aal in back.
    16x8 vizion wheels 0mm offset
    265/75/16 bfg's
  10. Feb 17, 2017 at 9:49 PM
    #390
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    White
  11. Feb 17, 2017 at 9:51 PM
    #391
    ecotecin
    WV
    Kinda has a cement color to it. Good looking single cab though.
    vrod671 likes this.
  12. Feb 21, 2017 at 6:11 PM
    #392
    RohoTaco2015
    RohoTaco2015 New Member
    Josh
    2015 tacoma sr5
    3 inch lift, wheels & tires
  13. Feb 26, 2017 at 11:51 PM
    #393
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Pretty much the same truck as mine, I'm thinking of putting a 3" lift on instead of the 6 I have now. Ever regret the longbox?
  14. Feb 27, 2017 at 6:34 AM
    #394
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    So my coworker just put in a 3/2in Readylift kit on her 2012 Tacoma. Is 265/70/17 the biggest size she can go without rubbing or having to add wheel spacers? Also, what is the best aggressive looking tire in that size? I have ko2s on my 3rd gen and that to me is aggressive looking already.
  15. Feb 27, 2017 at 6:35 AM
    #395
    Leo4x2
    Leo
    San Antonio, Tx
    Nice color match! I about to but these same wheels/size off a guy but decided to go with the couplers in 20x10
  16. Feb 27, 2017 at 7:00 AM
    #396
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    Wheel spacers make rubbing worse from my experience. Not sure about the rest of your question but anything is possible with cab mount relocation and fender chop
  17. Feb 27, 2017 at 7:14 AM
    #397
    Leo4x2
    Leo
    San Antonio, Tx
    Well that's what I was telling her, I got 285/70/17 on just a 2" level spacer and I had to get wheel spacers because I rubbed on the UCA's and after that rubbed on the fender and all that so she said she'd like to keep from having to chop and cut and all that stuff.
    So I guess question is what is the biggest size tire she can go with without having to cut/chop/grind on a 17" wheel?
  18. Feb 27, 2017 at 2:34 PM
    #398
    BohlaaH
    BohlaaH Loading...
    ALEX
    2015 TRD Sport DCLB
    33 she would need to cut the cab mount to not rub, so 33 minimal rubbing. Tire width matters as well
  19. Jun 5, 2017 at 8:04 AM
    #399
    Ewadh
    Ewadh Active Member
    Ed
    Forest, Va
    2008 Tacoma 4DR 4.0 TRD Sport
  20. Jun 5, 2017 at 8:11 AM
    #400
    ToyTaco06
    ToyTaco06 Member
    Blake
    Memphis, Tennessee
    2006 Red Tacoma Pre
    3 inch suspension lift Lower light bar
    3in. Toytec & Bilstein 5100's
