3 inch lift issues
Discussion in 'New Members' started by hvactech47, Aug 29, 2021.
  1. Aug 29, 2021 at 5:25 PM
    hvactech47
    hvactech47 [OP] Member
    Trevor
    Saraland Alabama
    2013 tacoma TRD off road 4x4
    3” spacer lift
    Hi all, first off I want to say I’m happy being a tacoma owner many of trouble free miles so far which leads me to my issue, I’ve installed a 3 inch lift the previous weekend. It was a spacer lift by supreme suspensions I understand now after the fact these aren’t the best. So far I have had no alignment done, and the stock tire sizes are still on at this time. I am feeling a slight vibration through the driver side floor board, I do have a carrier bearing drop installed plus differential drops installed. I have seen on here that it’s possible it is a needle roller bearing that should be replaced with a bushing. My question is is why would it make this half rotational (seemingly) vibration at speeds 30-55mph but not at high interstate speeds. I installed this lift in northern alabama at my dads and drove back to mobile al where I live. Have I cause more damage to this bearing in the diff? I drove around downtown mobile yesterday and didn’t have it this vibration seems to be when it’s first driven after awhile or randomly. Good news is I drive a company van to work and home everyday so it sits except once a week, any input or ideas if this is indeed the needle bearing would be appreciated. Also to note I lifted this truck to get around while hunting and needed more clearance. Nothing serious or major off-roading. Currently this tacoma has 135k and had 60k when I bought it.
    buckhuntin-tacoma likes this.
  2. Aug 29, 2021 at 5:52 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila and tcjacado like this.
  3. Aug 29, 2021 at 6:06 PM
    tcjacado
    tcjacado Well-Known Member
    Does the vibration go away when in 4wd?
    If so... you need the ecgs bearing to replace the stock needle bearing.
  4. Aug 29, 2021 at 6:06 PM
    hvactech47
    Trevor
    Saraland Alabama
    3” spacer lift
    Thanks! Glad to be here!
  5. Aug 29, 2021 at 6:10 PM
    hvactech47
    Trevor
    Saraland Alabama
    3” spacer lift
    I have tried it in 4 wheel drive and haven’t noticed it.. but also by the time I switch to 4wd the vibe was gone in 2wd.. it’s odd that it happened between certain miles per hour but not at higher speeds as in 60 mph plus. It’s also random when it wants to vibe like it does it’s never consistent.
  6. Aug 29, 2021 at 6:11 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    Drop it down to 2 inches and you avoid a lot of potential issues.
  7. Aug 29, 2021 at 6:12 PM
    tcjacado
    https://www.tacomaworld.com/threads...differential-bearing-vibration-thread.152173/
  8. Aug 29, 2021 at 6:13 PM
    tcjacado
    o_O
    You can't lower a fixed spacer
  9. Aug 29, 2021 at 6:15 PM
    hvactech47
    Trevor
    Saraland Alabama
    3” spacer lift
    Honestly if I can’t get it figured out and fixed I’m thinking about taking the lift back off it’s just sad because the new stance looks to great.
    tcjacado[QUOTED] likes this.
  10. Aug 29, 2021 at 6:16 PM
    Georgia Native
    A band saw can do anything.
  11. Aug 29, 2021 at 6:17 PM
    hvactech47
    Trevor
    Saraland Alabama
    3” spacer lift
    Still doesn’t explain why I got that vibe immediately after installation last Saturday night. It should’ve been vibrating before the lift as well if it was worn. I would understand if it was vibrating the way it does now before, I’m just confused on the matter. Cv axles are fine, they don’t pop or anything in 2wd or 4wd. There is no play in them I have checked.
  12. Aug 29, 2021 at 6:17 PM
    Georgia Native
    Probably the best move. Countless posts about people screwing their trucks up pretty good when lifting more than a couple inches.
  13. Aug 29, 2021 at 6:20 PM
    hvactech47
    Trevor
    Saraland Alabama
    3” spacer lift
    I just don’t get how a buddy of mine can lift his same height and same year model and not have issues. His tacoma also has more miles than mine and he has had zero issues whatsoever I even drove his to see if I felt the same issue but I don’t
  14. Aug 29, 2021 at 6:21 PM
    tcjacado
    It typically happens right after you lift it...
    But that thread covers all front end diff and CV axle vibrations. Spend some time and read, don't just assume.
  15. Aug 29, 2021 at 6:22 PM
    tcjacado
    No two trucks are alike really.... it's unfortunate, but the way it is on these things.
  16. Aug 29, 2021 at 6:23 PM
    hvactech47
    Trevor
    Saraland Alabama
    3” spacer lift
    Thanks f
    or the info, I’ll read around some more and take it to someone who deals with lifted trucks if I can’t figure it out, I will keep posted
  17. Aug 29, 2021 at 6:25 PM
    hvactech47
    Trevor
    Saraland Alabama
    3” spacer lift
    Ye
    ah it’s funny I had a z71 I lifted and had zero issues but I had heard of others having problems. I guess when this is figured out and settled I’ll let everyone know the for sure issue.
  18. Aug 29, 2021 at 6:27 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    tcjacado and hvactech47[OP] like this.
