3 inch lift kit question please help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by asiantacoma, Oct 17, 2011.
  1. Oct 17, 2011 at 12:30 PM
    asiantacoma
    asiantacoma [OP] Member
    asiantacoma
    boston
    08 gray double cab
    1.25spacer
    will my drive shaft life be affected if i install a 3 inch lift kit to my 08 tacoma
  2. Oct 17, 2011 at 12:57 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You might want to elaborate a bit... of course it will be affected with a lift, you're changing the angle in which it operates. There are things you can do to correct or prevent vibrations though but the driveline will be affected regardless.
  3. Oct 17, 2011 at 8:07 PM
    asiantacoma
    asiantacoma
    boston
    08 gray double cab
    1.25spacer
    thats what i was talking about, the angle of the front drive shaft to the wheel... and good thing you mention the vibrations. i guess its more of a hassle than i thought, just what i expected. i guess ill keep the suspension stock. thanks mike!!!
  4. Oct 17, 2011 at 8:13 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    It's a hit or miss with the vibes. I have a 3" lift and have no vibes.
    I just opened a can of worms. Awesome.
  5. Oct 17, 2011 at 8:16 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  6. Oct 17, 2011 at 8:17 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    that is such common and easy to remedy problem with any lift. i lifted my truck 3 in. bought the shims, etc. and did not end up using any of them. I think its a hit or miss on noticable vibrations. zero issues and lifted for almost 2 yrs.
