3 inch lift/level
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Will_Teasley, Jul 23, 2023.
  1. Jul 23, 2023 at 2:25 PM
    Will_Teasley
    Will_Teasley [OP] Well-Known Member
    Will
    06 Prerunner
    So I just got a 2nd gen and I’m looking into a 3” lift/level kit. Would I be able to solely purchase the strut spacers along with the lift blocks and U-bolts, or do I absolutely need aftermarket/extended struts and shocks?
  2. Jul 23, 2023 at 2:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Absolutely need?……..
    No.
    Is it something I ever advise anyone to do?
    Never.
  3. Jul 23, 2023 at 2:50 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Stay away from a drop bracket lift, it is extremely hard to reverse. Otherwise it’s your truck.
  4. Jul 23, 2023 at 2:54 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    if you are just looking to level out, I would look for somebody selling a 3rd GEN suspension, basically rear shocks and front coil overs it’ll give you the leveling and a little bit of lift maybe an inch
  5. Jul 23, 2023 at 2:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    Your Tacoma doesn't have struts.
    Over 2" starts putting things like CV joints at risk
    Lift doesn't make way for a larger tire package (in case that's you're unstated goal)
    Blocks and spacers are fine for Friday night lead-sled cruisers. There are better choices if you have other goals.
  6. Jul 24, 2023 at 3:49 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    if u go 3" you should get larger or bump stop extenders
    If you don't can crush the shock
