3 Inch Lift on 33’s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Christian01016726, Jul 23, 2019.
  1. Jul 23, 2019 at 4:32 PM
    Christian01016726
    Christian01016726 [OP] Member
    San Antonio Texas
    2013 DC TRD Sport 4X4
    So I’m upgrading my stock Taco soon with a 3in lift and I liked the idea of 33/12.50r15 BFGoodrich T/A Mud Terrain KM2’s. Should I expect any significant rub that would need any trimming?
  2. Jul 23, 2019 at 4:34 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I thought 15s would hit the caliper ?
  3. Jul 23, 2019 at 4:35 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Definitely trimming and can mount chop.956F2A09-1DC8-457D-8D5E-3D98BC7FA417.jpgthis is mine on 33x 12.5
  4. Jul 23, 2019 at 4:36 PM
    Texas T
    TX
    '14 T Force
    This too.
    El Duderino likes this.
  5. Jul 23, 2019 at 4:43 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    At this point I assume you're just trolling but if not, check out the cool search function....it has all the answers for you
    steveo27 likes this.
  6. Jul 23, 2019 at 4:47 PM
    Christian01016726
    San Antonio Texas
    Not a troll.. I’m just relatively new to trucks and I’ve found I love em. Obviously I’m kinda out of my league here so I guess I’ll do some more research. Any advise to avoid having my Calipers getting whacked, smaller size tire?
  7. Jul 23, 2019 at 4:52 PM
    Hillbilly Deluxe
    Hillbilly Deluxe Member
    Anthony
    08 Tacoma
    Lifted 3 inches k&n cold air straight piped 20x10 33-12.50-20
    How did you cut cab mount I'm on 3 inch spacer lift and 33-12.50-20 and rubbing cab mount
  8. Jul 23, 2019 at 4:53 PM
    Dalegribble02
    Go 16s or 17s not 15s wheels
  9. Jul 23, 2019 at 4:56 PM
    Christian01016726
    San Antonio Texas
    Appreciate your feedback.
  10. Jul 23, 2019 at 6:24 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Yup. 16s are the smallest wheel you want to run and grinding the calipers is a bad idea.
    With a 3" lift you are going to need upper control arms and will likely have vibration that you'll be chasing. This is covered in the suspension forum here.
    If you're set on 33s (285/75/16) you're most likely going to rub on the cab mount. The cab mount chop corrects this but it involves more than just trimming some plastic. If you don't want to do the cab mount chop (cut the frame and weld a plate on it), you can run 255/85/16.
    Check the wheel/tire forum for recommend wheel sizes and offsets and info on recommend tires and sizes.
    Some on here don't rub at all running 285s but your alignment needs to be perfect, with the correct wheel offest/backspacing/width and most of those that don't rub are likely mall crawlers.
    Dalegribble02 likes this.
  11. Jul 23, 2019 at 6:57 PM
    Texas T
    TX
    '14 T Force
    With an angle grinder/cutoff wheel. There should be lots of threads regarding the cmc.
  12. Jul 24, 2019 at 6:37 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    I run 285/65/18 with no rubbing at all. Wheels are -12 offset. I do some light off roading while deer huntin and no issues.
  13. Jul 24, 2019 at 7:32 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    If you with 305/65/17 tires it will give you the wider look but probably only minimal rubbing at full lock. You will most likely need adjustable UCA's to push the wheel forward and be able to align it. I get minimal rubbing at full lock when backing up with my setup and I did not do the cab mount chop. A true 33x12.5 tire will rub more because it's even wider. My wheels are 17x8.5 with -10 offset.
  14. Jul 24, 2019 at 8:09 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    :gossip: You can run 33s with a 2-2.5” lift if you’d like to go that route.
