3 inch lift on my 1996 tacoma 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tbone15, Feb 21, 2021.
  1. Feb 21, 2021 at 7:46 PM
    #41
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    I’m running 600 springs. I’ll check thread count but a 1 1/2 is suppose to be 2.5 lift
  2. Feb 21, 2021 at 7:48 PM
    #42
    Kwikvette
    Fresno County
    4 run, 2 don't
    On a stock vehicle, yes from 11 to 11.5 threads will be exposed to net roughly 2.5" of height on a stock truck.
    Since you haven't looked at your preload yet, or confirmed your spring length, we're just going back and forth pointlessly.
  3. Feb 21, 2021 at 7:48 PM
    #43
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Special order? The standard King springs for our rigs are 14" free height.
    Kwikvette[QUOTED] likes this.
  4. Feb 21, 2021 at 7:50 PM
    #44
    Kwikvette
    Fresno County
    4 run, 2 don't
    I actually second guessed myself twice when I posted; thanks for correction.
    *Edits old post*
  5. Feb 21, 2021 at 7:51 PM
    #45
    Tbone15
    Tbone15 [OP] Well-Known Member
    Trystan gates
    1996 toyota tacoma Xtra cab 4x4
    None yet
    @Kwikvette what's your complete setup and how much did it cost?
  6. Feb 21, 2021 at 7:53 PM
    #46
    Allex95
    allex
    Their 14 and 600 pound coils
  7. Feb 21, 2021 at 7:54 PM
    #47
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, I have a 4Runner so its different.
    My Tacoma ran Fox 2.5 front, Fox 2.0 rear, Wheelers Superbumps, BPV relocation bracket, and OME Dakar leaf pack. That'd run roughly $2300?
    4Runner was like...$3300? But that's adding cost of Durobumps front and rear, OME rear springs, offset lower rear links, and adjustable panhard bar.
  8. Feb 21, 2021 at 7:55 PM
    #48
    Tbone15
    Trystan gates
    None yet
    Ah thanks
  9. Feb 22, 2021 at 8:34 AM
    #49
    Kittenmittens4U
    Kittenmittens4U Well-Known Member
    Sam
    Denver, CO
    98 Xtracab TRD 3.4l Evergreen Pearl
    Airaid MIT w/deckplate mod Grey wire mod 265/75/r16 Duratracs 2.5 Extended Travel King Coilovers Built Right Fabrication Uca's OME Dakars W/AAL and 10' Bilstein 5125's Toytec U bolt flip and extended brake line.
  10. Feb 26, 2021 at 11:08 AM
    #50
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Here's my 2003 with the 3" Toytec Aluma Series kit [​IMG]
  11. Feb 26, 2021 at 11:29 AM
    #51
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    How’s the reverse light output on those taillights? I’ve been thinking about getting them. Look great. And did you paint your rear bumper?
    FreshOldTaco[QUOTED] likes this.
  12. Feb 26, 2021 at 12:53 PM
    #52
    FreshOldTaco
    kevin
    2003 Tacoma
    Reverse lights are a little dim but that could probably be resolved with brighter bulbs. The bumpers came painted from the factory along with the grill, door handles, and fender flares. That was part of the "color key package".
    And thank you :cheers:
  13. Feb 26, 2021 at 3:54 PM
    #53
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    add a diff drop on that sucker. Fix that axle boot angle.
  14. Feb 26, 2021 at 3:56 PM
    #54
    98_3RZ_NIC
    damn that’s a beautiful truck.
  15. Feb 27, 2021 at 3:49 AM
    #55
    FreshOldTaco
    kevin
    2003 Tacoma
    Thanks!
    98_3RZ_NIC[QUOTED] likes this.
  16. Feb 27, 2021 at 9:33 AM
    #56
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Locking hubs help me out in not having to worry much about it. The truck isn't my daily driver either, I think I've only put 10k miles on it in the last four years...
  17. Feb 27, 2021 at 9:43 AM
    #57
    98_3RZ_NIC
    Wow! Very nice!
