3 inch lift options
Discussion in 'Suspension' started by Penz83, Sep 6, 2012.
  1. Sep 7, 2012 at 9:01 AM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I have no problem with using blocks in the back. Just finding the right coils/shocks for the front I think is the main problem. All the stuff I found is a bit too pricey haha
  2. Sep 7, 2012 at 9:11 AM
    Penz83
    Penz83 [OP] Well-Known Member
    05 Tacoma pre runner dbcb short bed
    In my case I'm going to need new shocks soon anyways, might as well save up and lift my truck the right way.
  3. Sep 7, 2012 at 9:15 AM
    Penz83
    Another thought... If I did a 2.25" spacer lift in the front, and the issue is bottoming out, could I add 2.25" to the bump stop and eliminate that issue?
  4. Sep 7, 2012 at 9:48 AM
    Penz83
  5. Sep 7, 2012 at 9:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    Those are the shocks I was talking about in my first post. You don't need 2.5" blocks in the rear. That won't level it. You only need 1.5" in the rear (IIRC). You can get an AAL for that.
    Call DSMS and talk to Sonny or Marco. They will set you straight on what you want. They are a vendor here and offer free shipping
    http://www.tacomaworld.com/out.php?url=http://www.downsouthmotorsports.com/
  6. Sep 7, 2012 at 10:00 AM
    Penz83
    Awesome thanks for the info man. Forgive my newb question, what is AAL?
  7. Sep 7, 2012 at 10:13 AM
    98tacoma27
    Ben
    Not Beech Creek
    AAL = Add A Leaf
    Looks like this and goes in your exsisting leaf pack. You can get a set for under $100.
  8. Sep 7, 2012 at 10:15 AM
    Penz83
    Ahh ok, and that adds 1.5"?
  9. Sep 7, 2012 at 10:17 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    2.5" or more you may need new aftermarket UCA to get your alignment back in spec. I would suggest 5100's set at 2.5" and 1.5" AAL in the rear.
  10. Sep 7, 2012 at 10:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    They are available for a few different lifting heights, yes.
  11. Sep 7, 2012 at 10:24 AM
    Penz83
    I guess the only thing im not understanding is how the shock adds 1" of lift in the rear.
  12. Sep 7, 2012 at 10:25 AM
    Penz83
    I may need uca? Will I or won't I haha.
  13. Sep 7, 2012 at 10:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Shocks do not add lift.
  14. Sep 7, 2012 at 10:25 AM
    sirsaechao
    Tim
    CA
    The rear always sits higher due to hauling and towing and using the bed. The front has the engine so it sits lower. Hence the rake. Look at all trucks...the front always sits lower...so people want to level or get a leveling kit.
  15. Sep 7, 2012 at 10:27 AM
    #35
    Penz83
    That's what I thought. So if I add 2.5" of lift in the front, shouldn't I add 2.5" in the rear to keep it level?
  16. Sep 7, 2012 at 10:27 AM
    #36
    sirsaechao
    Tim
    CA
    I heard people running 2.5" and got the alignment back to spec and I heard some that can't. So be warned that you may need to invest another $450 for new UCA's.
  17. Sep 7, 2012 at 10:27 AM
    #37
    Penz83
    Got it! Thanks
  18. Sep 7, 2012 at 10:30 AM
    #38
    98tacoma27
    Ben
    Not Beech Creek
    I doubt it. The only alignment issue you MAY have is the caster angle. Ideally you want it to be >2.4°. Even if it is not, it doesn't effect tire wear.
    No. The rear sits higher with the stock suspension. You only need 1.5 in the rear with 2.5 in the front.
  19. Sep 7, 2012 at 10:31 AM
    #39
    98tacoma27
    Ben
    Not Beech Creek
  20. Sep 7, 2012 at 10:34 AM
    #40
    Penz83
    Thanks for the info, was worried about the uca.... And i see now why only 1.5"AAL is needed in rear.
    Cool thanks for the help guys, I think I got my lift squared away.
