3 inch lift question
Discussion in 'Suspension' started by 02TACOMA, Apr 22, 2009.
  1. Apr 22, 2009 at 4:10 PM
    02TACOMA
    02TACOMA [OP] Member
    Reidsville NC
    tacoma TRD 4x4
    magnaflow exhaust,cold air intake
    I have a 02 tacoma double cab trd 4x4 it currently has stock 265/75/r16's. I'm thinking of getting a 3" leveling kit will 285's(33's) fit. Seems like it would sense the 265's fit stock with no rubbing... Any suggestions to run 33's ("with a budget of about $1000")would be appreciated:)Thanks
  2. Apr 22, 2009 at 6:12 PM
    Dockhead
    Dockhead Formarly 08TRD4X4RadientRed
    Chico, CA
    08 ACC 4X4 TRD OR
    TRD Seat covers, K&N Series 77 intake, TRD plate frames, iPod interface
    You should be fine cause a true 33 is a 305 i believe, and also most 3 inch kits will allow you to run a 33 with little to no trimming.
  3. Apr 22, 2009 at 8:42 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Ya with a 3" kit you should be able to run 285/75/16s no prob (33s)
  4. Apr 22, 2009 at 8:52 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Keep in mind guys he has a first gen.
    Our 2nd gens can fit 33s with minimual trimming after a 3" lift. I can't remember on my 02 as I never lifted it.
  5. Apr 22, 2009 at 9:04 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    You will be fine man! Just stay away from the spacer lifts... I had one and it was a really harsh stiff ride. It sucked!!! Upgrade and do it right the first time, Check out Toyteclifts.com...
    Prefer- Coilovers or OME lift
  6. Apr 22, 2009 at 9:17 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    ftr 305 is a width
    a 305 is wider than a 285 which is wider than a 265 and so on and so forth
    the 2nd number in a metric tire size can be used to figure out height
    for example
    a 255/85/16 is roughly 33" tall but skinny...whereas a 285/75/16 is ALSO 33" tall but a bit wider
  7. Apr 22, 2009 at 9:18 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    ALSO
    depending on which wheels and tires you go with...you could possibly still experience some rubbing...especially on the frame rail and pinch weld
  8. Apr 22, 2009 at 9:44 PM
    Dockhead
    Chico, CA
    08 ACC 4X4 TRD OR
    My bad, the guy at the used tire place was telling me that a 305 was taller than a 285
  9. Apr 22, 2009 at 9:46 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    its possible...it really depends on what that 2nd number is
    a 285/75 and a 305/70 should be almost identical in height and close to an inch different in width
  10. Apr 23, 2009 at 8:37 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Every number there effects every other number, you can't change 1 with out changing another with the exception of the rim that will remain the same yet affect the tire size.
  11. Apr 23, 2009 at 9:11 AM
    stikkimikki87
    stikkimikki87 Well-Known Member
    Pensacola FL
    d44, 37s, all 4 wheels turn!
    uhh...everything? lol
    285s will prob rub just a hair, 305s WILL RUB QUITE A BIT. If you dont mind trimming 1-2" off the front bumper at the bottom so you can turn then the 305s might be ok. I would get the 285s, they will fit better.
  12. Apr 23, 2009 at 11:41 AM
    Pestilence
    Pestilence Active Member
    Austin, TX
    09 tacoma
    Tinted windows LOL, they look sharp as shit tho...
    Ok so im the new guy on the forum and just bought my first truck....can someone explain what all the numbers being thrown around apply to?? 255/85/16?? what is this in terms of lift height and suspension??
  13. Apr 23, 2009 at 11:43 AM
    Rippin101
    Jax Beach, FL
    2014 TRD Sport 4x4
    Check out the Tire Size Calculator under the Mods and Tutorial button at the top of the message board bar.
  14. Apr 23, 2009 at 11:44 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    255/85/16 or any set of numbers similar are metric tire sizes
    with the first number being the width, 2nd being sidewall height in terms of a ratio with the width, 3rd being rim size
  15. Apr 23, 2009 at 11:49 AM
    GA1044
    GA1044 Well-Known Member
    San Marcos, TX
    2002 trd 4x4
    Air Hog, Grey-Wire Mod, Fabtech Coilover 3.5 Lift, Deck Plate Mod, Rear Diff Breather Mod, Magnaflow Exhaust
    you will need a spidertrax wheelspacer (1 1/4") for them not to rub in the front. I did the Fabtech leveling coilover kit with AAL and installed STT's LT285/75r16 but didnt not fit untill the next day when i received the spacer. I cranked the coil up to 3". my profile has the pictures, dont forget to put some up when you finish.
  16. Apr 23, 2009 at 12:01 PM
    Pestilence
    Austin, TX
    09 tacoma
    Thank you for the help fellas. fast too!! lol
