3 inch lift/ shock question
Discussion in 'Suspension' started by mjm540ii, Aug 16, 2011.
  1. Aug 16, 2011 at 4:02 AM
    mjm540ii
    mjm540ii [OP] Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Hey fellas,
    A couple months ago I put a 3" lift under my 2010 trd sport, with a 3" front (via the typical 1.5" spacer) and 2 " lift blocks in the rear. Everything is good except the stock rear shocks seem to be maxed out, making speed bumps and such harsh. I was wondering what kind of shocks to replace the stock rear shocks with, or if there is a certain stock preferred by the forum for 3" lifts already in place via lift blocks.
    Thanks guys
  2. Aug 16, 2011 at 4:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bilstien 5100's in the rear would help.
  3. Aug 16, 2011 at 4:15 AM
    mjm540ii
    Oxford, PA
    Should I just be able to throw those in, replacing the rear stockers?
  4. Aug 16, 2011 at 4:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep.
  5. Aug 16, 2011 at 4:57 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    OP, I would read this thread or call Downsouth Motorsports, some people are having trouble with the 5100's in the rear in a lifted application. There's another shock (can't remember if it's the 5125 or 5150) that works better in lifted applications and allows more downtravel so you don't max out the shock. 5100's would dampen better than stock shocks and may be all you need but if you off road you may want to consider all your options. FWIW, I have a 2" lift in the rear and am very happy with my 5100's, I have not maxed them out but I mostly stay on roads or fairly flat trails.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/167652-busted-my-5100-a.html
