3 inch lift, trimming and CMC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fitz95, Jun 26, 2016.
  1. Jun 26, 2016 at 9:33 PM
    Fitz95
    Fitz95 [OP] New Member
    '13 TRD Off-Road
    Hey everyone. I'm in the market for some wheels and tires. Just got a Toytec 3 in. Boss lift with light racing UCA's and am wanting to put 285/70/17 on her. Looking at a set of wheels 17x9 with +1 offset. Ive read tons of threads covering this topic, but it goes everywhere from backspacing to offset being the issue. How much trimming and, if any, CMC will I need to be doing? I'm trying to avoid CMC as much as possible. Thanks for the help!
  2. Jun 26, 2016 at 9:42 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    With that size tire you'll have to do bmc regardless. If you get a wheel that's inward so much that you don't have to bmc then you tire will hit control arm. After that minor wheel well flare trimming is likely going to be necessary
  3. Jun 27, 2016 at 6:28 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Im running 285/70R17s and I did not have to CMC. Everyones truck is different and if you do UCAs also, you can adjust the caster even further to move them off the cab mount a little bit. My tire also doesn't hit my control arm. I only had to trim a tiny tiny bit of inner fender plastic.
  4. Jun 27, 2016 at 7:26 AM
    Aclark29
    Aclark29 Member
    Andy
    Kaysville, UT
    2006 Tacoma trd sport
    Spectre intake
    Bump. I'm doing the same thing to my taco soon. Keep me posted on what happens
  5. Jun 27, 2016 at 1:40 PM
    maxtherat
    Inland Northwest
    Very true they are all a little different as are the actual tire sizes depending on manufacturer.
  6. Jul 21, 2016 at 4:47 PM
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Maybe not the right thread, but I am gonna throw it out there anyhow, as an avid do-it-yourselfer. I can make the CMC cut and get the pre-fab covers to weld back on...my question is since I have a wire feed welder , 120vac, what size wire and heat would suffice to make a decent weld? Any suggestions or techniques to get a decent solid weld?
    I can lay down a bead but am looking for somebody in the know for feedback on this one.
  7. Jul 21, 2016 at 4:50 PM
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    my sliders are being welded on with .025".... so that or .030" probably.
    sorry for thread jack
    arkywally[QUOTED] likes this.
