3 INCH LIFT / WHEEL TIRES THAT FIT IT
Discussion in 'New Members' started by BRANDONTACOMA, Jun 13, 2023.
  1. Jun 13, 2023 at 1:09 PM
    BRANDONTACOMA
    BRANDONTACOMA [OP] New Member
    2023 TACOMA SR
    I'm sure this has been posted a million times but I'm new to forums and navigating them, I have a 23 Tacoma SR 4x4 v6 and was wondering if I do a 3 inch lift what is the max tire/wheel size combo will fit (offset / backspacing).
    buckhuntin-tacoma likes this.
  2. Jun 13, 2023 at 1:53 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    BRANDONTACOMA[OP] likes this.
  3. Jun 13, 2023 at 1:55 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
  4. Jun 13, 2023 at 1:56 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Is there any reason you are posting multiple threads in multiple forums on the same topic? I chimed in on your thread below.
    https://www.tacomaworld.com/threads/3-inch-lift-wheels-and-tires.804199/
    Please save the all caps thread titles for emergency situations when you are stuck on the side of the road and need help immediately. All caps for a general question may be considered to be rude by some. Just my $.02 for forum courtesy.
    Mark77 likes this.
  5. Jun 13, 2023 at 2:32 PM
    BRANDONTACOMA
    2023 TACOMA SR
    @mic_sierra Sorry I'm at work and I use CDK it is a habit lol
    mic_sierra likes this.
  6. Jun 13, 2023 at 2:41 PM
    BRANDONTACOMA
    2023 TACOMA SR
    @mic_sierra I am new to navigating forums I figured multiple posts more avenues for answers .. is how do I delete posts on here?
    also A lift not influencing tire size doesn't make sense to me. Is there no straight forward answer anyone has to tires and wheels that fit a 3rd gen with a 3 inch lift or do I just pay 3k to hope it fits.
  7. Jun 13, 2023 at 2:56 PM
    mic_sierra
    Elsewhere
    Dude. Check out the video I linked in your other post. It is a multivariate equation. It isn't just a matter of changing one variable (lift). You have to consider many things and Tinkerer's Adventure does a better job than I ever could explaining things. There are countless posts already on this site that have tire size and the lift each member is running so if you want to see what works, do some searching. I highly recommend you understand the implications of a lift and all variables involved in an independent front suspension BEFORE you make a decision so you can evaluate your use case and understand potential problems / solutions before parting with your hard earned $$$.
    If you want to be spoon fed an answer: I am running an OME-005 Heavy 2.5 in lift, SPC UCAs with ~4 degrees of caster, and 275/70/17 KO2s and the only rub I get is minor inner (plastic) fender rub at full lock and full stuff. I don't full-send when off roading as I pull a 3500# off-road travel trailer and save the full send for my mountain bike.
    Check out Classy's Garage after you check out Tinkerer's Adventure on YT if you want to see what duder had to do to fit 295s.
