3 inch Spacer lift opinion.
Discussion in 'Suspension' started by shaman06, Jan 9, 2011.
  1. Jan 9, 2011 at 6:55 PM
    shaman06
    shaman06 [OP] Well-Known Member
    SoCal
    2013 sport
    I just got a 3 inch EZ-lift kit installed on my 06 tacoma with spacers in the front and an aal iin the back. I have been hearing alot of talk about alignment problems and shocks breaking with spacers, if i don't do any heavy off roading, what is the worst that can happen with this kind of lift? Also would uca's help prevent any damage with this?
  2. Jan 9, 2011 at 7:01 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    What kind of spacers? Preload or top plate?
  3. Jan 10, 2011 at 5:59 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    x2, the "worst thing that can happen" is different depending on which type of spacer the OP has.
  4. Jan 10, 2011 at 6:39 AM
    Eman
    Eman Member
    Eric
    O,Fallon MO
    2002 Tacoma TRD 4WD
    3 inch Extreme truck toys lift.( 3 inch front spacer- Fabtech aal.) 1 inch diff drop Lightspeed UCA,s Energy steering rack bushings
    (EZ-lift kits use top plate spacers-on top of shock-strut) Alignment problems are going to be the same with what ever you use to lift the front.
  5. Jan 10, 2011 at 6:51 AM
    MaddMaxx
    MaddMaxx Member
    Western North Carolina
    '93 Pickup
    Glass-Pack Muffler
    I've been considering the Toytec 3" Spacer Lift with the rear AALs.
    Reason for this is because this is one of the lifts that the local dealership will install themselves and still stand behind the warranty.
    I'm sure that this is not the best lift (Procomp or Fabtech is probably the best (IMO)), however, the fact that it would be covered in the warranty is the attractive part for me.
    Whether or not this is true, idk. It's just what the stealership told me.
    Any of you guys have this Toytec lift?
    If so, ever have any of the previously mentioned problems? faster wear?
  6. Jan 10, 2011 at 6:59 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    LOL at dealership warrantying a lift that they would give you a hassle about if done in your garage.
  7. Jan 10, 2011 at 7:00 AM
    Namyo
    Namyo -
    only thing voided from warranty is what is modified...spacer voids the front struts...new coil over voids old coil over :p Pay extra and get a better lift.
    uca will help alignment, ride, and travel. If you don't do heavy off roading u wont break a shock....interstate travel of 70mph on an old road will require sum "buck up and hang on"
  8. Jan 10, 2011 at 7:09 AM
    TexasTacoma37
    Okay, if they are top-plate spacers, they can cause two issues:
    1. By lengthening the entire shock assembly, your bump stops are useless. You will bottom out the shock before you hit the bump stops.
    2. By forcing the whole shock assembly down, you put a lot of stress on your ball joints.
  9. Jan 10, 2011 at 7:12 AM
    MaddMaxx
    MaddMaxx Member
    '93 Pickup
    Glass-Pack Muffler
    Right. It's BS that they would void something you do yourself, and stand behind something they do, even if it's exactly the same.
    But if that's what it would take to maintain warranty, I think I would pay a little more to have them do it, than do it myself or put something else on, and them not back up the warranty at all.
    I know about the Magnuson-Moss Warranty Act, but not 100% sure about its verbaige and what covers what.
  10. Jan 10, 2011 at 7:47 AM
    shaman06
    SoCal
    2013 sport
    Could I get bilstein shocks with the spacers to improve the performance?
  11. Jan 10, 2011 at 7:48 AM
    TexasTacoma37
    Won't do much since they are top-plate spacers. They don't stiffen the ride to begin with.
  12. Jan 10, 2011 at 7:51 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I ran coil spacers for over a year out in lower Idaho. no rock crawling but I did wheel it alot and I never had any problems other than it rode rough as shit.
    I upgraded to fox coilovers and I will NEVER run spacers in anything ever again.
