3 inch spacer lift or bigger tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasona250, May 16, 2010.
  1. May 16, 2010 at 8:13 PM
    jasona250
    jasona250 [OP] Well-Known Member
    jason
    ventura california
    07 double cab prerunner trd offroad
    i have a pre runner with the stock trd off road tires would it look weird if i got 3 inch spacer lift. or should i get bigger tires
  2. May 16, 2010 at 8:18 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Both...and avoid Spacer lifts
  3. May 16, 2010 at 8:19 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    By that I meant getta 3" lift and get bigger tires too
  4. May 16, 2010 at 8:23 PM
    jasona250
    jason
    ventura california
    whats wronge with the spacers
  5. May 17, 2010 at 2:59 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Do a search, there seem to be a bunch of horror stories about spacer lifts. They also aren't the best off road. If you stay on the pavement it is fine though.
  6. May 17, 2010 at 6:07 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Can't get much bigger tires without the lift, so def. get the lift first. And +1 for avoiding spacers. Why lift a $25,000 truck with a $100 piece of metal?
  7. May 17, 2010 at 5:41 PM
    tacomapilot
    tacomapilot Member
    Nick
    Arizona
    07 Tacoma Sport
    day-time running lights mod, afe pro dry s air filter, ipod isimple adapter, more to add...
    I'm in the same dilemma about the spacers vs lift.... I also have a prerunner, 2 wheel drive and I rarely ever leave the pavement of a road, so i'm really considering the spacer route... I have also just considered just putting bigger tires, which seem to probably be maxed out at 275/70/r17... anything larger is gonna be rubing the wheel-well....
    I probably didnt help at all, and just added confusion.... sorry dude,.... once you make a decision though, put some pics up
  8. May 17, 2010 at 6:53 PM
    KPT
    09 Prerunner
    The largest you can run without rubbing is 265/70/17.
  9. May 19, 2010 at 6:22 AM
    kerusm
    kerusm Member
    Kirby
    Carson, MS
    05 Prerunner TRD
    285/70/17 Bridgestones
    I have a 2005 prerunner and have 285/70/17 on it. It works. There is a bar on the inside of the tire well (not sure what it is called) that it barely touches when I max out turn left or right. Never touches in normal driving conditions. Had them on for a couple of years and love the new look and stance it gave the truck.
  10. May 19, 2010 at 7:00 AM
    KPT
    09 Prerunner
    Welcome to TW! I take it you have wheel spacers or aftermarket wheels with less backspacing?
  11. May 19, 2010 at 7:10 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    probably not hwy 285/70/17 bridgestones will clear 95 % of the time like he says
    275/70/17s will fit fine on a stock truck ...if they are not MTs in most brands.
  12. May 20, 2010 at 4:28 AM
    kerusm
    kerusm Member
    Kirby
    Carson, MS
    05 Prerunner TRD
    Thanks. Everything is stock and wiscdave is correct. They are Bridgestone but they are Dueler's A/T Revo's.
  13. May 20, 2010 at 5:46 AM
    rjclemen
    rjclemen Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    could you post some pics? I was curious how the taco looked stock with max tire.
  14. May 21, 2010 at 5:29 AM
    kerusm
    kerusm Member
    Kirby
    Carson, MS
    05 Prerunner TRD
    Yes, I will post some after lunch today.
  15. May 22, 2010 at 4:30 AM
    kerusm
    kerusm Member
    Kirby
    Carson, MS
    05 Prerunner TRD
