3 inch Suspension lift options
Discussion in 'Suspension' started by drifter, Aug 19, 2010.
  1. Aug 19, 2010 at 5:20 PM
    drifter
    drifter [OP] moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    First, this is probably covered throughout this site in various places, but I would rather ask again and get the info in one spot so that it is easier to understand.
    Ok, I'd like to lift my truck about 3 inches so that I can run some 33's (currently running ~stock 31's) when I need new tires (not gonna happen for awhile). I won't be doing much hard wheeling *prerunner*;) so a body lift would be the best, cheapest route but... I want a suspension lift so that I can have more overall clearance.
    I'm mainly worried about the front end...the rearend should be a piece of cake with some AAL's or blocks.
    I know that new coilovers are the best bet, but I don't want to spend $1000+. I figured on getting a coil spacer lift, like a revtek, tough country or truxxx kit. Then I found out that they really stiffen the ride, shorten travel, cause a chance of breaking stuff etc.
    So, now I figure that some bilstein 5100's
    or some eibach coils
    or some OME coils might do the trick.
    Which choice would be better? Is there any other, maybe better, shocks similar to the bilsteins? Would a combination of 2 of the above 3 work? I've read somewhere that pairing up the bilsteins with aftermarket coils is bad. I've also read that the ride will be really rough with bilsteins and stock coils. What's my best bet here? I'm trying to keep it below $500.
    1999 taco prerunner is my rig
    thanks for any help
  2. Aug 22, 2010 at 3:45 PM
    drifter
    Sam
    Oregon
    good stuff
    Which is better:
    1, Bilstein 5100's for 2.5 inches of lift.
    2, eibach lift coils
    3, OME lift coils
    4, combo of the above
    truck = 1999 taco prerunner
  3. Aug 22, 2010 at 6:48 PM
    bevans
    bevans Well-Known Member
    GA
    Best
    1. OME (full kit- springs & shocks)
    2. eibach w/ 5100 set at .85
    3. 5100's set at 2.5
  4. Aug 22, 2010 at 6:48 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    OME all the way
  5. Aug 22, 2010 at 7:18 PM
    drifter
    Sam
    Oregon
    good stuff
    Thanks for replying.
    Dang, OME coils + shocks would run my over $400 just for the front end. :(
    that's if I got and .
