3 inch toytec lift kit
Discussion in 'Wheels & Tires' started by Louisianimal247, Mar 23, 2017.
  1. Mar 23, 2017 at 8:23 PM
    Louisianimal247
    Louisianimal247 [OP] Member
    2011 TRD Sport 2wd|2019 TRD OR DCSB 4x4
  2. Mar 23, 2017 at 8:31 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    32" but then again you can fit a 32" tire without the lift. You can run a 33" but will rub on the cab mount. If you do a cab mount chop like almost everyone on here then you can run 33's comfortably. If you take it up a couple notches by beatin the shit out of the pinch welds, cutting a few inches off the fenders and front bumper along some other modifications you can fit 35's.
    DustStorm4x4 likes this.
  3. Mar 23, 2017 at 8:32 PM
    Fiend13
    Chad
    I did a cab mount chop and installed this kit but withou LR the coil spacers and I run 33's. Basically sitting at 2.5" of lift and have been like that for the last 4 years.
  4. Mar 23, 2017 at 8:38 PM
    Louisianimal247
    Ok thanks for the info
