3 inches lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cluless@Tacoma1, Mar 5, 2025.
  1. Mar 5, 2025 at 9:31 AM
    Cluless@Tacoma1
    Cluless@Tacoma1 [OP] Member
    Need more info… I plan on doing a leveling kit on my 2021 Tacoma TRD Sport with a 3 inches Spacer front and 2 inches block Rear. Is this a good budget friendly lift? If so, what should be done? I heard I need to do a differential swag bar drop? Is that true? Help? I kinda knew to this. Just need to have more ground clearance, nothing fancy. Also will the ride be more firmer?
  2. Mar 5, 2025 at 9:50 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    :popcorn:
    dryheat and RIX TUX like this.
  3. Mar 5, 2025 at 10:00 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Some may need new upper control arms to align the front end properly. The rear lift may require offset shims to combat vibrations. Those with a carrier bearing may also need a spacer to drop that bearing about .75 inches. The front diff drop is generally not needed unless you get vibrations.
    I went with a 2.7” front lift (with OME springs) and one inch rear blocks. I only added the carrier bearing drop kit and never experienced vibrations. I have about 150K on this setup.
  4. Mar 5, 2025 at 10:04 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Terrible idea. Why do you need more ground clearance? You are just asking to break stuff with a spacer lift if you will be driving anywhere but to the mall. Gotta pay to play around here. You can get a Bilstein 5100 front lift and add-a-leaf rear for about $600 and it will be much better than spending $400 on junk that will break CV shafts.
    dryheat, RIX TUX, wood714 and 2 others like this.
  5. Mar 5, 2025 at 2:20 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    x2 :popcorn:
    RIX TUX likes this.
  6. Mar 5, 2025 at 2:34 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Budget friendly? Barely. Good? Not. Like Don mentioned, get a nice 2" 5100 Bilstein lift up front with stock springs, and with no more than a 1" block in the rear. If you carry stuff in the box, then make it a AAL in the rear instead.
    Spacer Lifts are not your friend, not to mention your tires will look tiny with a 3" Lift.
    Chew likes this.
  7. Mar 5, 2025 at 2:41 PM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Bigmatt503 and Tocamo like this.
  8. Mar 5, 2025 at 5:03 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    hi clueless
    why do you need a lift?
    what is a swag bar?
    3 in lift with stock tires your plan?
    T4R_hereforbearings and dryheat like this.
  9. Mar 5, 2025 at 5:11 PM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    You're gonna have a bad time... especially with that lift. It is not budget friendly at all, you will require aftermarket upper control arms, and the sway bar spacers, and you may as well schedule an appt with a Chiropractor and a Neurologist, maybe even a Neurosurgeon after the very rough and painful ride you will have. Seriously, you're heading down a road that you will be very miserable with. You want ground clearance, but for what? Lift does not equal clearance for larger tires. When you add that 3" spacer lift in the front, you are maxing out the length of the stock shocks and leaving zero down travel, which will make your spine compress and you will feel every bump in the road. It'll be fun at first, until you drive more than 10 minutes, and then you will hate your truck and your back will never be the same.
    Take heed, just because it's sold and available, does not mean it works and is a good budget friendly idea like the advertising says. There is a good reason people here are grabbing their popcorn and waiting for the comments here, please don't do this to yourself.
  10. Mar 5, 2025 at 5:15 PM
    Clearwater Bill
    Billy
    Largo Florida
    There's a whole sub forum on suspensions
    And a search function as well
    Suspect both would be quite helpful in your journey
  11. Mar 6, 2025 at 6:33 AM
    dryheat
    dryheat Well-Known Member
    RIP OP :(
    Tocamo and RIX TUX like this.
  12. Mar 6, 2025 at 4:33 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I feel like op will never return.
    Long story short nope none of that is a good idea. Start searching through here there and hundreds of threads that hold all of the answers and more.
    Cliff notes
    Spacers increase the overall length which leads to numerous issues.
    Over 2" you can have all kinds of vibration issues and alignment issues without a uca added in.
    I just hope you have bigger tires planned ss stock with that lift would look rediculas. But with that comes a whole other can of worms for fitment and wheel specs etc....
    Get a 0 offset wheel with a one upsized tire, better look use and less issues. Can be done on a similiar budget
