3 Leaf Progressive Add A Leaf Kit
Discussion in 'Suspension' started by harshest, Mar 20, 2009.
  1. Mar 20, 2009 at 12:58 PM
    harshest
    harshest [OP] I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Anybody running a truck with these on them? Specifically I am looking at Wheelers Off Road. Just wondering if they provide the full 1.5" of lift, how much they sag over time, did you install them with or with out the TSB springs?
    I have the non TSB springs.
    Thanks
  2. Mar 20, 2009 at 7:07 PM
    ComaTosin
    ComaTosin The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    I have not installed them but plan to do so in the next couple of weeks. They ar eon backorder with wheelers. I also have the NON TSB spring that are flat as a board. My friend is also orderinf and installing on his truck with TSB at the same time. I should have a report in a couple of weeks. Seems like a good option. I will likely also use a 1" block to level out with my lift up front.
  3. Mar 20, 2009 at 7:28 PM
    harshest
    Michigan
    05 PreRunner SR5
    Nice keep my updated when you get them installed.
