3" Lift, 16x8 with 285s on 2nd Gen?
Discussion in 'Wheels & Tires' started by eltaco, Jul 2, 2012.
  1. Jul 2, 2012 at 4:50 PM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    Trying for the life of me to figure this one out. I've run a few different setups, and a buddy of mine is looking at running this one. He was told by a local shop that he could run a 3" lift, 16x8 with a 0 offset and 285/75/16s without issues. The guy said there would be minor modifications required to the plastic, but that's it. Really curious if any of you guys are running this setup and what all was required to do so. I've run setups with less wheel outside of the fender walls and had rubbing, but maybe I just didn't trim enough? At any rate, I just really want to confirm that he's not going to have to chop cab mounts to run this setup.
    I'd love to hear from your experiences if you've run this on your rig. Pics just to show it off are perfectly welcome :)
  2. Jul 3, 2012 at 7:43 AM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    The answers I find here will determine whether I change my setup or not. Hope someone has some insight for me.
  3. Jul 3, 2012 at 7:55 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It all depends on if you/ He wheels the truck 285's will rub no matter how much you trim. For street driving plastic can be trimmed and have no rubbing issues. you might need UCA's to push your castor forward to stay clear from the cab mount. But the first time you take it off road you will see 285's rub no matter how they are set up.
  4. Jul 3, 2012 at 7:59 AM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Thanks for the reply.
    I'm running camburg UCAs and he'll be running Light Racing UCAs.
    My main concern is will it hit that cab mount. That's a whole other level of correcting rubbing.
    As I'm setup now the only rub I've seen is on the frame at the inside of the wheel at full lock under compression. Just enough rub to wear the coating off.
  5. Jul 3, 2012 at 8:09 AM
    JLee
    Jerry
    Grass valley CA
    Your really not going to know until you put the tires on. if you wheel the truck you will need to do the cab mount chop mod there is just no way around that. It's really easy to do if you can weld or know someone that can.
  6. Jul 3, 2012 at 8:22 AM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    I have the Toytec 3 inch lift and 285-75-16 BFG on factory TRD rims with no rubbing and factory UCA's
  7. Jul 3, 2012 at 8:27 AM
    JLee
    Jerry
    Grass valley CA
    Have you had your LCA all the way to to bump stop with no rubbing?
  8. Jul 3, 2012 at 8:30 AM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Yes
    I know one day I will be doing something that will require some trimming, but so far no issues
  9. Jul 3, 2012 at 8:44 AM
    Raddbus
    Raddbus Well-Known Member
    Russell
    Santa Maria
    TRUE BLU TACO
    Illuminated 4X4 switch, 3" lift,
    I have a 3" spacer lift, 285/75/16, had to cut just a little plastic, Stock UCA's, no rubbing now. Couldn't be happier.
  10. Jul 3, 2012 at 8:49 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Nice looking truck!! :thumbsup:
  11. Jul 3, 2012 at 8:51 AM
    masshole taco
    masshole taco Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    I have 285x75.r16 with a 3inch lift and I had to some trimming.. I run dick cepek's and I believe they have 4.5 of backspacing but don't quote me..
  12. Jul 3, 2012 at 8:52 AM
    Raddbus
    Russell
    Santa Maria
    TRUE BLU TACO
    Thanks OffroadToy
  13. Jul 3, 2012 at 8:54 AM
    JLee
    Jerry
    Grass valley CA
    Yeah once you really stuff the tires you will find you need to trim mor then you thought.
    I can tell just from your pic you would rub off road I know not everyone wheels their truck but if you did you would rub. Im just trying to tell the OP his options for a street truck to mild fire roads you wont have to trim much. Start stuffing your tires and flexing out the rear and you will be rubbing all over.
  14. Jul 3, 2012 at 10:25 AM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I went to an off road park here in Texas and was very surprised the I did not rub. We were taking level 3 trails. I bet the one day I make a sharp turn and hop a little curb it will rub. I did have to put 1.25 spacers though
  15. Jul 3, 2012 at 1:36 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Trim plastic only or any metal Fab? That's even further out than either my buddy or I are considering.
  16. Jul 3, 2012 at 1:40 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    you need an AAL to get rid of the bro lean.
  17. Jul 3, 2012 at 5:05 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Yeah, I don't find much enjoyment in low-speed rock crawling and wheeling, nor do I jump my daily driver (very high). I guess it's all what you're after. I do like high speed dirt roads, but regardless of what you hit on that, you'd best not have your wheel turned very far while driving at speed or you have more to worry about than some rubbing :D
    I ordered the spacers and I'll see what modification would be needed to run them. If I determine it'll create enough problems to warrant frame modification, I'll ditch the spacers and stick with where I'm at.
  18. Jul 3, 2012 at 5:05 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Im running a 3" as well blisten 5100 and eibach springs with top plate spacers. 285's and same rim size as well.
  19. Jul 3, 2012 at 5:07 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    What size wheel and what offset? How much trimming?
    That's really what I'm trying to dial in on.
  20. Jul 3, 2012 at 5:10 PM
    BlueTaco07
    Cody
    Looking
    285/75/16 bfg A/T 16x8 Xd hosses 0 offset 4.53 back spacing. None I let the tires burn down the little bit of rubber they hit not much at all though.
