3" lift /17x9 0r x8/ 275 tires
Discussion in 'Wheels & Tires' started by SoCalBlack08, May 7, 2009.
  1. May 7, 2009 at 5:38 PM
    SoCalBlack08
    SoCalBlack08 [OP] Well-Known Member
    CA
    08 PreRunner DC
    ok well my lift will be here soon so gotta get tires and rims.
    i was looking and the backspacing and stuff confused me.
    what bs should i be looking for?
    do i need new lug nuts?
    should i go 17x8 or 17x9?
    are 275 tires less likely to rub and do they look bad with 3'' of lift like 265's?
    oh and im gunna throw this Q in...will the tsb aal lift the back to 3"
    pics are welcome to give me some ideas of rims and tires :)
    thanx
  2. May 7, 2009 at 6:07 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    #1) ur looking at maybe 2.5" or so from TSB and the TSB AAL
    #2) the most common BS for aftermarket wheels that work for us is 4.5"/0 offset
    #3) i'd go 17x8 w/ 285/70/17
    #4) prolly need to get a set of acorn style lugs, but dependant upon the wheel
    #5) 275's would be less likely to rub and wouldnt look bad, but for the amount of trimming, may as well go 285's
  3. May 7, 2009 at 6:27 PM
    rdmccart
    rdmccart Member
    Panama City, Florida
    08 Tacoma 4x4 Sport
    Push bar, tool box, nerf bars
    I went with 17 x 9 with 4.5" offset with 265 x70R17 and 3" toy lift and they scrub every now and then when backing up and turning hard.
    So if you want the bigger tires i suggest the 17 x 8
  4. May 7, 2009 at 7:27 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I agree with Jhodge.
  5. May 9, 2009 at 6:12 PM
    SoCalBlack08
    CA
    08 PreRunner DC
    ok so a 17x8 rim will rub less?
    thanx for ur help guys
  6. May 9, 2009 at 6:22 PM
    Lane Cypert
    Lane Cypert Well-Known Member
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    I have 17X9 MM 951's with 265/70 17s. The offset is -12 and they don't rub at all with the Toytec Ultimate lift with the coilovers set at 3.
