3" lift- 285/75/16 or 255/85/16??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXTaco13, Oct 10, 2013.
  1. Oct 10, 2013 at 8:23 PM
    TXTaco13
    TXTaco13 [OP] Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Planning on getting Icon Stage 2 3" suspension setup, but I am torn between the 285/75/16 and the 255/85/16 :confused:. I'd prefer to not have to trim, but if need be I will do it as long as it is minimal. If you have a 3" lift and either of the tires sizes please chime in a let me know the advantages and disadvantages! Thanks!
  2. Oct 11, 2013 at 9:29 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There's some guys reported that they are running 255/85 on stock wheels with stock suspension and no trimming. No off roading either. See the 255/85 thread in the wheels & tires section.
  3. Oct 11, 2013 at 10:56 PM
    easystickerco
    easystickerco Well-Known Member
    San Diego
    Tacoma SR5
    id go 285/75/16
  4. Oct 11, 2013 at 11:16 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    x2. I run this size and I had to get new rims with more backspacing because the tires rubbed on the UCA's. I also had to do pretty minor trimming.
  5. Oct 12, 2013 at 1:24 AM
    ACKtrd30
    ACKtrd30 Nice Guys don't finish last. Boring guys do.
    Massachusetts
    2016 Desert Storm Trooper
    3", 285/75/16 here. No rubbing in any situation. My 2008 had the same setup, just different wheels. Rubbed at full lock. Ymmv. I'd go with 285's
  6. Oct 12, 2013 at 1:33 AM
    JohnnyWayne
    JohnnyWayne The Past Through Tomorrow
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Look out for snakes in the grass guerrilla marketing.
    Putting lift and 285's on today, will let you know how it turns out op.
  7. Oct 13, 2013 at 12:05 AM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Thanks for the reply. I do like the stance of yours. I'm really wanting the BFG All Terrains, Ive always ran them and get really good mileage out of them since 80% is on pavement. Do you have spacers? How much trimming if any? Do they rub on your UCA's?
  8. Oct 13, 2013 at 12:09 AM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Thanks for the input! Aftermarket UCA's?
  9. Oct 13, 2013 at 12:10 AM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Thanks! Which lift are you going with?
  10. Oct 13, 2013 at 12:12 AM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Thanks for the heads up! Aftermarket UCA's?
  11. Oct 13, 2013 at 12:28 AM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Thanks! You would think though that with stock suspension there would be rubbing like crazy... That 255 is big compared to the stock size!
  12. Oct 13, 2013 at 12:32 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Uca's are upper control arms. They are need to maintain proper alignment and are normally needed at lifts greater then 2.5 inches. They are also stronger then factory ucas and allow more travel. What part of Texas are you in OP?
  13. Oct 13, 2013 at 1:12 AM
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I was asking if his UCA's were stock or not. I decided on uniball vs. heim joint. They are cheaper and don't squeak as much.
  14. Oct 13, 2013 at 1:16 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I would go 255/85/16
  15. Oct 13, 2013 at 1:17 AM
    BulletToothTony
    Ah ok then disregard my post :)
    X2 after this set of 285's goes I think I'll try 255's next...
  16. Nov 27, 2013 at 2:20 PM
    tacoflaco
    tacoflaco Well-Known Member
    Sean
    Bay Area, CA
    2013 ACLB Baja
    SnugTop SuperSport SpiderTrax 1.25" Spacers BAMF Sliders OEM smoked headlamps Pro Grille Paint matched grille surround Tepui RTT
    How did it turn out? Any rubbing. I'm doing the ToyTec ULK and UCAs. Would like to mount up 285/75/16 to my OEM TRD wheels but would prefer not to have to do any trimming or the cmc. I have 265/75/16 right now and have no rubbing in any situation so far on or off road.
  17. Nov 27, 2013 at 5:40 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    I would go 255/85's on a 2" lift.
    or
    285/75/16 on a 3" lift.
    285's look so damn good, but 255's are taller and usually do just as well if not better offroad and onroad.
  18. Nov 27, 2013 at 6:08 PM
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    Woah so 285's do fit fine on stock wheels. I'm in the same boat as you OP. Decisions decisions lol.
    How much of a spacer are you running Beavis? I'm guessing 1/2" to get 5 BS?
