3" lift 33" Tire - does it work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 21greenXPoffrd, Oct 27, 2021.
  1. Oct 27, 2021 at 5:53 PM
    21greenXPoffrd
    21greenXPoffrd [OP] Member
    Dave
    21 Army green, offroad X series
    none
    I'm going with Ironman stage 2 lift kit with the standard nitro shocks for a 3" lift.
    The question I have is which tire? - since some tires are slightly less than 33" and some slightly more.
    Examples: (2) sizes of Nitto Ridge Grapplers with different heights: (I'm keeping my 16" TRD wheels)
    - LT 285/75R16 Height = 32.83"
    - LT 295/75R16 Height = 33.39"
    .56" difference in height, but they are both advertised as 33" tires.
    Is there someone who can respond from their experience on 33" tires with a 3" lift?
    Other considerations: I'm going to go with extended break lines just to avoid possible issues - I also have a question for the forum ?is there a preferred break line?
    What else am I missing?
    Thanks in advance!
  2. Oct 27, 2021 at 6:04 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Skinnies are what you seek.
    coma toy and AmateurTaco1313 like this.
  3. Oct 27, 2021 at 6:06 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You likely don’t want or won’t actually receive a 3” lift. There’s only about 3” of down travel from the factory. Shoot for 2”. The bigger the tire the more chance of rubbing. It’s up to your preferences. You don’t need extended break lines because you are not changing the max down travel (aka droop) of your suspension. You will not be extending them any more than a stock truck sending it.
    CherylJane likes this.
  4. Oct 27, 2021 at 6:08 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    If you plan on taking it off road, My suggestion is to not go with a three inch lift.
    The CV axel angle can lead to broken CV joints much more readily. Many here have recommended not going over the two inch mark for this reason.
    I had a three inch lift initially, with 285/75 r16s. I rubbed the cab mounts on full turn when hitting deep bumps or during articulation off road and also the front of the lower control arm. Before purchasing rims, I used spacers to alleviate the LCA rub and did a cab mount chop to make it functional off road. A 295 tire is even wider and can exacerbate the above issues.
    Also, the stock upper control arm does not accommodate a 3 inch lift, so that’s an additional cost.
    To not go down the rabbit hole of making a functional truck with wide 33s, stick with a 2 inch lift and some 255/85 ‘skinny’ 33s IMHO
  5. Oct 27, 2021 at 7:54 PM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    I want to go from a 285/70/17 to a skinny tire, but on a 17x9 wheel my options are limited.
  6. Oct 27, 2021 at 8:07 PM
    gudujarlson
    Minnesota
    Did you get rid of your stock wheels? I’m still running mine.
  7. Oct 27, 2021 at 8:12 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    33” fits fine on my stock 89 :anonymous:
  8. Oct 27, 2021 at 8:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You don’t say
    CalcityRenegade and Chew like this.
  9. Oct 27, 2021 at 8:55 PM
    Woodini
    Ray
    89 Pickup 22RE 4wd
    :thumbsup:
    Junkhead[QUOTED] likes this.
  10. Oct 27, 2021 at 9:48 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Curious about your reasons?
  11. Oct 27, 2021 at 9:56 PM
    Bishop84
    Bishop84 Well-Known Member
    You don't need extended brake lines.
    You'd benefit more from upgraded upper control arms.
    JoeCOVA and NorNev like this.
  12. Oct 28, 2021 at 4:12 AM
    NorNev
    Dave
    A Few
    Yep
  13. Oct 28, 2021 at 4:29 AM
    NorNev
    Dave
    A Few
    I read the skinny tire thread- the wheels are turning now.
    Stocklocker[QUOTED] likes this.
  14. Oct 28, 2021 at 6:25 AM
    gudujarlson
    Minnesota
    If you already cut up your truck to fit 285’s why go to 255’s? I think the only really well tested advantage of 255’s is that they fit without modification. I take all the other claims (better in snow, etc) with a grain of salt. If already cut up my truck to fit 285’s and I wanted a change I might try a skinny 35 rather than a skinny 33. You are maybe half way to fitting them.
  15. Oct 28, 2021 at 6:26 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Depends on alignment, wheel backspacing etc. probably need a CMC and might want to consider UCA to help with alignment corrections.
  16. Oct 28, 2021 at 6:28 AM
    NorNev
    Dave
    A Few
    In all honesty I’ll probably go 285/75/17
    SKOL!
  17. Oct 28, 2021 at 6:31 AM
    NorNev
    Dave
    A Few
    This^ Definitely look into UCAS- I like the JBA’s, been running them for 55k miles, lube them up at every oil change
  18. Oct 28, 2021 at 7:29 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I have the Ironman Foam Cell lift and honestly it is only about 2.25" in the front and the leaf pack adds about 2.5" in the rear depending on what rate you opt for. I'm running 33.2" tires have haven't had to cut or chop anything. The stage 2 UCA moves that spindle forward enough to clear the 33" tires off the cab mount. The issue you will run into is backspacing and rubbing on the UCA. I have a limited so I'm running 275/70R18 and with the stock 18" wheels, I barely rubbed the UCA at full lock. Put in a 6mm spacer and it is perfect with no rubbing at all. I don't drive with the spacer on...I just put them on when I get to the trail and remember not to turn full lock on the road. That being said, I don't know what the back spacing is on the stock TRD 16" wheels but with a 285 or 295 wide tire, you may need a 1/2" spacer which would require longer wheel studs.
    As for the brake lines, stick with stock. You don't need to extend them at all. What you will encounter is the mounting bracket for the e-brake cable will need to be modified with the lift. I just used a piece of 10ga steel with a couple holes drilled in it to keep the bracket in the stock location.
  19. Oct 28, 2021 at 8:21 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Get some 33x10.5x17 Kenda Rts. They are a true 33, and work great in all conditions. I ran those for a couple months with 0 offset/8.5 wide wheels, and just barely rubbed on the body mount at full flex.
  20. Oct 28, 2021 at 10:55 AM
    coma toy
    coma toy Off Road Taco
    Another vote for skinny 33's. 255/85/16 or 255/80/17
    NorNev likes this.
