3" lift and 285/70/17 on fj's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darektylka, Nov 9, 2013.
  1. Nov 9, 2013 at 7:34 PM
    darektylka
    darektylka [OP] Well-Known Member
    Darek
    Chicago
    Taco TRD Sport DCLB 4x4
    I have a 2006/Trd Sport/4x4 Tacoma, I have some 3" lift, I am looking to put some 285/70/17 with the stock FJ Cruiser 17" wheels[​IMG], does someone knows if that will work??? Or will I need spacers.?
  2. Nov 10, 2013 at 6:59 AM
    darektylka
    Darek
    Chicago
    anyone?
  3. Nov 10, 2013 at 6:59 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Do you know the BS of the FJ's?
  4. Nov 10, 2013 at 7:01 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    You'll need spacers... I believe they are the same backspace as the 17" sports.
    Just get some 1" boras
  5. Nov 10, 2013 at 7:34 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I have a set of 285's on these and run them with Spidertrax. If the b.s. is different than the Sporties it will be by a small amount. I think it may depend on how big your 285's run. MT's and wide shouldered AT's are more likely to touch a stock uca.
    Edit: the offset is definitely different. They stick out a half inch further than the Sporties but I am not sure how much more inner clearance you get. I could check further when at home later tonight.
  6. Nov 10, 2013 at 12:41 PM
    darektylka
    Darek
    Chicago
    Their the 6 spoke 17" fjs they stick out a bit further than stock sporties so BS is definitely different. Ill be looking on getting 285/70/17 A/T tires
  7. Nov 10, 2013 at 12:42 PM
    darektylka
    Darek
    Chicago
    where's a good place to order spacers from? How wide of spacer will I need to clear the 285s on the fjs?
