3" lift and jack?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCFirefighter, Jun 25, 2010.
  1. Jun 25, 2010 at 5:32 PM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Does anyone know if the stock (emergency) jack is any good after a 2.5-3" lift? Also, I'm considering getting a more decent jack for home use.
    What's customary: A jack and 4 jack stands? Only two and work one axle at a time? Can I lift an entire axle with the jack, and use the two stands to completely take it off the ground?
    But, most importantly, will the emergency jack still be of use in case I need it.
  2. Jun 25, 2010 at 5:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yes. It works fine in a pinch.
  3. Jun 25, 2010 at 5:46 PM
    SCFirefighter
    Stephan
    Cary, NC
    Thanks
  4. Jul 6, 2010 at 6:56 PM
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    How would you use the stock bottle jack in a pinch for changing tires, it isn't high enough when fully extended is it? I'm sure you are right :eek: so what am I missing?
    Thanks! :D
  5. Jul 6, 2010 at 6:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. It will work fine, unless you are running 35's.
  6. Jul 6, 2010 at 6:58 PM
    08BlackTacoma
    08BlackTacoma Well-Known Member
    South Florida
    09' Double Cab V6 SR5, Long Bed, TRD Sport
    this is a good question, i have a feeling mine wont reach!
  7. Jul 6, 2010 at 6:59 PM
    SCFirefighter
    Stephan
    Cary, NC
    I haven't tried, but I asked the same question not too long ago, and got the same answer from Chris. I might just try it tomorrow afternoon. Why not try it too? :)
  8. Jul 6, 2010 at 7:00 PM
    BBiggs
    BBiggs Well-Known Member
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    Hey everyone. Throw a block of wood or something under your stock jack. Problem solved.
  9. Jul 6, 2010 at 7:04 PM
    08BlackTacoma
    South Florida
    Yeah, I will try it this week just to know in case i am stranded in the middle of no where. I suppose worst case is i can cut a square block or 2 and keep them under the rear seats too.
  10. Jul 6, 2010 at 7:47 PM
    Ace83
    Ace83 Well-Known Member
    TX
    SR5
    Bilstein Front shocks, Rough Country 3" lift kit, 5" black railway running boards
    ^^ easy and cheap lol
  11. Jul 6, 2010 at 7:52 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    yea , but the answer is really no the stock jack is garbage ive got a 3" suspension lift and the jack comes know where close to the frame but ive used wood to correct the problem:D if you can help it though get a better and taller jack, saftey becomes and issue when cutting corners:rolleyes:
  12. Jul 6, 2010 at 8:56 PM
    Ace83
    TX
    SR5
    true, an adequate jack is the right thing.. if can get one then do it
  13. Jul 7, 2010 at 12:30 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Yea, I got a flat while offroading over the weekend... the jack does reach, it went a lot higher than I had expected, but it didn't bring the tire off the ground, I had to use oswego's jack under the lca. I figure a thick block of wood on the bottom would work.
  14. Jul 7, 2010 at 5:14 AM
    jmed99
    SC
    I did try it and it doesn't reach. Chris4x4 says it will work so I'm sure it will...I'm just wondering what I'm doing wrong. I don't think mine would work with a 2" block.
  15. Jul 7, 2010 at 5:23 AM
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
  16. Jul 7, 2010 at 6:49 AM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    If you look in the owners manual, you will see where to lift the truck from to change tires, its not on the frame. The bottle jack will work fine for lifting the LCA and rear axle as stated in Manual even with 3" lift.
    But a block of wood would work also.
  17. Jul 7, 2010 at 6:49 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Mine will reach the rear pumpkin but not the front 1/2 anywhere. I have a 2.5 in the front and just the tsb in the rear now (not that that matters) and 32's.
  18. Jul 7, 2010 at 6:58 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I picked up a bigger bottle jack from harbor freight to replace my factory jack. Its stronger and lifts higher. make sure you try it out before you actually need it though. the first one I got didnt lift my truck at all, no fluid in guessing, took it back and the second one worked fine.
    as for a garage jack I got one of the big orange floor jacks from harbor freight. they also have lightweight (blue) floor jacks that are pretty decent and have cupons for them for like 60 bucks
  19. Jul 7, 2010 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. Now, I havent tried to jack up my truck on the trail, so I imagine a block of wood would be needed there, if not a better jack.
  20. Jul 7, 2010 at 8:34 AM
    jmed99
    SC
    Ok...I looked at the directions printed on the stock bottle jack itself...if you follow those directions, it will not work but I'll have to look at the directions in the owners manual. Sounds like they contradict the directions on the jack.
