3" Lift and New Tires need suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2008Tacoma4.0V6, Feb 4, 2012.
  1. Feb 4, 2012 at 10:21 PM
    2008Tacoma4.0V6
    2008Tacoma4.0V6 [OP] New Member
    Derek
    Oregon
    08 SR5 4X4 4.0V6
    3" Lift
    Hey all.
    I am new to the Forum so ill put that up front also new to being a Tacoma owner but loving it.
    Now to my questions.
    1. I want to do a 3" suspension Lift (going to have it professionally installed however) any ideas on what lift to use. Tuff country was recommended to me already ideas on this specific one?
    2. I want to do a beefy looking tire but good for road driving thats mostly what i do? Previously i have had toyos and really like those. Opinions?
    3. Tire size i was looking at either 32's or 33's? Again I would love some insight.
    Thanks Everyone
  2. Feb 4, 2012 at 10:23 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  3. Feb 4, 2012 at 10:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  4. Feb 4, 2012 at 10:29 PM
    2008Tacoma4.0V6
    Derek
    Oregon
    08 SR5 4X4 4.0V6
    3" Lift
    Okay,
    Great thanks for the info on the lifts what about the tire sizes.
    I wont really be doing much off roading it more of a commuter vehical, if i did it would be light.
    I am most likely going to les schwab because i dont have the means or the time to do the work right now i was told installed the 3" suspension lift would be about $575
  5. Feb 4, 2012 at 10:33 PM
    OZ-T
    Peter North
    British Columbia
    You won't find too many people here recommending a spacer lift .
  6. Feb 4, 2012 at 10:36 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    with stock coils, bilstein 5100s will raise the front of the truck up to 2.5 inches
    and an add-a leaf will raise the rear up to 2 inches, and 5100s ride better than stock.
    the largest tires you can run without rubbing is 265/75r16, or 265/70r17
  7. Feb 6, 2012 at 3:35 PM
    ckyttle83
    ckyttle83 Member
    CT
    2011 Tacoma TRD
    25% tints Weathertechs Kenwood DX770 DVD Bug Deflector HID's Locker Mod
    I am also in the same boat, new to the forum. I have done a lot of reading on other threads, I see a lot of different opinions which bring a lot of confusion... Have a 2011 trd tacoma and would like a 2-3 lift with bigger tires. Not trying to break the bank and realize you get what you pay for. Suggestions for a happy medium on lifting and tires without rubbing?
  8. Feb 6, 2012 at 3:44 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    save your money and buy the toytec ultimate lift its a great lift for a great price.
  9. Feb 6, 2012 at 3:45 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Basically anything above 265/75r16 will rub offroad
  10. Feb 6, 2012 at 3:49 PM
    OZ-T
    Peter North
    British Columbia
    Best all around bang for your buck will be the OME lift kit with an AAL
  11. Feb 6, 2012 at 7:31 PM
    tacoduck
    tacoduck Member
    fritz
    florida
    2011 tacoma off-road
    thinking about the same for my 2011, 2-3 inches, mostly to hold a ARB bumper and to look a little more aggressive. I am thinking ome, 886.
  12. Feb 7, 2012 at 5:48 AM
    prerunner13
    prerunner13 Member
    Jeff
    Richlands NC
    2011 Prerunner sport
    2 1/2 ZONE off road spacer lift. 285/70/17 17x9 Ultra Gauntlet wheels Flowmaster
    I know most people are against space lifts but if you are not going to be off-roading and just want a little lift for bigger tires I would go with the ZONE off road spacer lift for $99 and run 285/70/17.
  13. Feb 7, 2012 at 6:24 AM
    Boilermaker99
    Boilermaker99 555
    Andrew
    Atlantic beach
    1999 SR5 TRD 4x4 3.4 V6
    ARE cap, Rhino lined bed, Custom Advantage-Max seat covers, Kenwood stereo and speakers, Debadged all emblems, blackedout grill, Off road lights, engine bay LEDs, Uniden Cb, Bedlined rockers and rims, Custom front and rear bumper, Hilo jack and mounts, Yakima load warrior, Magnaflow 14" muffler, Intake/prefilter, rebuilt frontend after accident so sort of frankensteined!!
    This is the point I am at on my build as well. After reading hours here and elsewhere on line, Here is what I have come to.
    Tuff counrty is like the Coleman gear of camping equipment, you can make it work but I woulnt want to buy something twice, nor trust it way back in the woods! REAL cheap but not what you want unless you want it to "look cool" ridin high!! Not very tuff as the name implys.
    Toytec ULK is good but it is a bilstein either way you look at it. They are adjustable, but how often with your bigger wheels are you going to be able to crawl under your truck and adjust them or would you, which also changes your alignment when you do it. A coilover is a coilover just Toytec has adjustable ones. The price seems cheap but only comes with an AAL for the rear and a shock not a full leaf pack. So you just put all of the pressure on one new leaf??? If you want it to go up just put the whole pack on, cause if you dont you will have a saggy rear soon. No one like your rear saggy....
    OME all around with the Nirto shocks, Dakar rears leaf pack with an AAL with the Nitro shock, 2" rear shackle. This setup can be purchased pre assembled for an extra 100 bucks. I have found it online for the kit sans AAL for 998. and you dont need the AAL unless you haul or tow stuff like gear, or tools, or firewood. Dont need the rear shackles unless you haul, it will raise the rear a tad.
    With this kit you get a 2.5-3" lift.
    Spacers do give you a bump , but basically preload your springs as well- dont do it. You can use a 10mm trim spacer to help with the leveling from a 2" shackle, but dont stuff a huge spacer up there
    Tacomas are not suggested to ever go over a 3" with out many other mods.
    With the OME you can replace the UCA but it is said not nessacery for proper alignment. This can be done later if needed. As well as the diff drop. Many on here have said you have to do it, and many have said they push their lifts to the limit with no problems on an offroad and didnt drop the diff.
    All in all for the money, ease of install, quality- OME seems to be the bees knees. Just one mans opinion based from many mens opinions.
    Tires- personally best for the money and commute, which I dont have and do all the time, best bet is a BFG AT, 31" for stock and up to 33" with a 3" lift. No spacers or offset needed as long as you dont go wider. Keep a 10.5" on stock wheels, go to the 33" with the OME lift, and you will be good. BFG AT dont look bad either, they got a little meat and look nice. Also the 10.5" will keep the gas in the tank longer than the 12.5" people are stuffin in their fenders!!! And you wont have to listen to the harmonic vibration from an MT back and forth to work, while still having the ability to go offroad with the AT.
    My setup soon to come to my build it as follows:
    OME 3" lift w/ Dakar spings and AAL, and front coilovers.
    33" BFG AT on stock bedlined wheels.
    With this setup you basically get a four in gain in clearence- 3' from lift and 1" from bigger rubbers. Thats what I have come to. Thats all I got.
  14. Feb 7, 2012 at 6:28 AM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2015 DCSB TRD OR 4x4
    5100's front & rear , Eibach springs, LR uca,Icon progressive aal
    tuff country 3'' w/285x75x16 is bad ass
  15. Feb 7, 2012 at 7:06 PM
    ckyttle83
    ckyttle83 Member
    CT
    2011 Tacoma TRD
    As a newbie I'll take constructive criticism. I would like your feed back on my options, one of the reasons I signed up here. I have looked into getting the add a leaf/ U bolt kit/front and rear 5100's. What else would I need to level out my truck and add a few inches of lift for slightly bigger tires... 265/75/16
    Looking at the Bilstein Adjustable lift kit with 5100 shocks on Toytec.
    Will I need the add diff drop 4x4 and what do you guys suggest for the rear lift options, 1.5 lift rear blocks with U bolts OR 1.5 TSB add a leaf?
  16. Feb 8, 2012 at 6:14 AM
    Boilermaker99
    Boilermaker99 555
    Andrew
    Atlantic beach
    Why adjustable? Cause you cant pick a height? Just plan on running thru tires due to poor alignment from changing your adjustable shocks
  17. Feb 8, 2012 at 8:37 AM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    Sub'd.
    Thanks for posting this one, I've been toying with the idea of a small 2-3" lift since I bought my truck. I don't do much off roading, but some of the roads I drive for work almost qualify, and sometimes I like to go have some fun.
    Might make my running boards useful to someone other than a lawn gnome, too :D
  18. Feb 8, 2012 at 4:09 PM
    ckyttle83
    ckyttle83 Member
    CT
    2011 Tacoma TRD
    I am aware that changing the the height would cause camber or toe wear without an alignment and I don't plan on changing the height once everything is installed and I get my truck aligned. Like I said I am new to tacoma's and am just trying to look over and see what options work best for me and hopefully getting feed back from people who know the field better than I do.
  19. Mar 13, 2012 at 10:27 AM
    zham61
    zham61 Active Member
    Dr.
    Utah
    '12 Tacoma TRDOR /Entune
    So what do you guys think is a good price for a Tuff Country or Truxx 3" Lift kit installed (for those of us that aren't mechanically savvy)?
    Also will you notice a big difference BETWEEN the stock 265/70/16 versus the 265/75/16?
    I'm new to this stuff and any advice would be really helpful. I don't plan on off-roading hardly at all, I'm just looking for aesthetics--bigger beefier truck.
  20. Mar 13, 2012 at 10:33 AM
    OZ-T
    Peter North
    British Columbia
    I don't get the concept of dropping $30K on a truck , then putting the cheapest lift on it you can find
