3" lift measurements???
Discussion in 'Suspension' started by ETaco23, Jul 13, 2010.
  1. Jul 13, 2010 at 9:18 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I think my Toytec coilovers have settled/sagged over the last 4-5 months. And I would like to know what are some people's measurements from ground to fender flare. With 285/75/R16 AT's.
    Im at 38-3/4" both sides. And when I first set them tey were closer to 39-1/4"
    I would like to adjust them, But its ganna be nearly impossible... :( Thanks!
  2. Jul 14, 2010 at 10:10 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I've got Toytec springs with 5100's, these are not the already built coilover set. Originally I was at 39.5" with 2" of thread on the collars and I lowered it to 38.5" to even out with the back. They felt stiffer are the higher setting and I replaced a spacer lift which had me at 38" so I'm happy where it's at. These are rough estimates but if factory is at 35"? 285 km2s give me 1" that means the coils are giving me 2.5". From what I've read every truck is a little different so I just played with it until I liked where it was at. However, with the new coils I'm now rubbing on the cab mounts so those are getting chopped today for $150 both sides. The spacer lift had no rubbing.....go figure!
    Good luck man!
  3. Jul 14, 2010 at 10:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    38.5" gives you 3" lift with 33" tires.
    Tac0maSteve likes this.
  4. Jul 14, 2010 at 10:33 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Never owned the truck stock so wasn't sure what the factory height was. So I could probably lower it another .5" and keep it at 38". Would like to take advantage of travel and shock dampening more than lift. After that spacer lift I relized I'm looking more for a better ride and I thought the Toytec's would be a little softer with the 600lb spring. I'm happy with them though!
  5. Jul 14, 2010 at 6:23 PM
    ETaco23
    Evan
    PNW
    Is that measurement the same for the 1st gens.
    Cause Im not exactly sure what I need to be at with my 285's.... Is 38-3/4" right?
  6. Jul 14, 2010 at 6:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent measured the stock first gen
  7. Jul 14, 2010 at 8:20 PM
    ETaco23
    Evan
    PNW
    Can Anyone else help me out?
  8. Jul 14, 2010 at 8:27 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Do your tires have good clearance/no rubbing? You should be good. It sounds like we both have about the same height.
    Nice truck by the way, it looks great!
  9. Jul 14, 2010 at 8:32 PM
    ETaco23
    Evan
    PNW
    Thanks man! I like yours too.
    Yeah, I have some rub but not much. Im just wanting to know if my front coilovers are still at 3" lift or if they've sagged a little. Bc I really dont know what measurement I should be at....
