3" lift options??
Discussion in 'Suspension' started by adamw, Jan 31, 2011.
  1. Jan 31, 2011 at 7:14 PM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    I have read a bunch of posts on what peope have done and looked at thier builds, but I still have no idea what a good set up looks like for a prerunner. I want something that wont give me problems while keeping it under $500ish. anything would really help. thanks!
  2. Jan 31, 2011 at 8:29 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Setup for a prerunner will be the same as 4x4. For the most part. Except you can do spindle lifts... That's going to be out of your price range though.
    Go for bilstein 5100's all around. U can set the front to 2.5 and hey an add a leaf.
    Or check out Old Man Emu lifts. You'll be able to get a full 3 inches with that lift. But might exceed your price range. Think of the possibility of getting new upper control arms when u get to 3 inches of lift.
    OR... Get a 3 inch spacer lift. Cheap. Lifts your truck. You'll sacrifice some ride quality tho.
    Keep searching you'll find something...
  3. Jan 31, 2011 at 10:17 PM
    adamw
    sunnyvale, CA
    If I go with bilsteins all around will I need the spacers and/or ALL's and /or UCA's?
  4. Jan 31, 2011 at 10:51 PM
    wolfdog2314
    Brush Prairie
    Go for bilstein 5100's all the way around.
    Set the front to 2.5.
    Get a 1.5 or 2 inch AAL for the back.
    U won't NEED new uca's. 1.5 inches of lift is about as high as you go before you should get new ucas. Alignment still gets in/close to spec at 2.5.
  5. Jan 31, 2011 at 10:52 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
    Thats a good lift for starts for sure!
  6. Jan 31, 2011 at 10:53 PM
    wolfdog2314
    Brush Prairie
    2.5* inches is about as high as you wanna go before uca's
    *I want edit feature from TW mobile skin* :-D
  7. Feb 1, 2011 at 6:45 PM
    adamw
    sunnyvale, CA
    so new uca's for 2.5"+ lift regardless if its a spacer lift or 5100s?
  8. Feb 1, 2011 at 7:17 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Save up for spindles! I wish I did.
  9. Feb 1, 2011 at 9:48 PM
    wolfdog2314
    Brush Prairie
    You won't get more then 2.5 inches with 5100's. You'll be fine with no new ucas at that.
    I'd assume 3 inch lift is 3 inch lift, so yah new ucas are reccomended at that point. Some people do, some people don't. Depends how well u want your alignment is spec.
  10. Feb 1, 2011 at 10:04 PM
    adamw
    sunnyvale, CA
    if I just did 5100s up front set at 2.5" how much lift would i need in the back?
  11. Feb 1, 2011 at 10:19 PM
    wolfdog2314
    Brush Prairie
    You can go 1.5 or 2 inch Add a leaf. Stay away from blocks.
    I have about 2.5 up front and went with 2 inch AAL. I think it looks great this way. But if u want less rake and more level go with 1.5 AAL.
  12. Feb 1, 2011 at 10:21 PM
    wolfdog2314
    Brush Prairie
    Here's mine with 2 inch AAL and 2.5ish up front.
    Search around to find some more pics to see what you like.
  13. Feb 1, 2011 at 10:23 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
  14. Feb 1, 2011 at 10:26 PM
    adamw
    sunnyvale, CA
    yeah I like that its nice and what tire size can you get in with that set up?
  15. Feb 1, 2011 at 10:33 PM
    wolfdog2314
    Brush Prairie
    If u get an aftermarket wheel with backspacing of 4.5 you can fit 285/70/17 or 285/75/16. (same size different wheel size)
    Even with this you'll have to do some plastic fender and mud flap trimming. Or get wheel spacers.
    Or stay with 265/75/16.
  16. Feb 1, 2011 at 11:49 PM
    KalamaKid
    285/75/16 and 285/70/17 are not the same size. The 285/75 will be bigger!
  17. Feb 1, 2011 at 11:58 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Save up and get allied 4 inch lift spindles and AAL in the back.
  18. Feb 2, 2011 at 7:52 AM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    Nothing wrong with a small block. I ran a 2 inch Deaver pack and a 1.5 inch block for 3 years on my previous truck with no problems.
  19. Feb 2, 2011 at 7:57 AM
    705 Taco
    Dean
    2016 TRD OR AC
    They are pretty close.
    Original tire
    Sidewall: 8.42 in
    Radius: 16.42 in
    Diameter: 32.83 in
    Circumf: 103.14 in
    Revs/mile: 614.31
    New Tire
    Sidewall: 7.85 in
    Radius: 16.35 in
    Diameter: 32.71 in
    Circumf: 102.76 in
    Revs/mile: 616.60
    Speedometer reading with new tire is 0.37% too fast.
    When your speedometer is reading 60mph you are actually traveling 59.78mph.
  20. Feb 2, 2011 at 9:10 PM
    adamw
    sunnyvale, CA
    if i set them at 2.5 would i need spacers/coils or would i be good to go?
