3" lift options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CentralFlaTaco, Dec 24, 2011.
  1. Dec 24, 2011 at 7:59 AM
    CentralFlaTaco
    CentralFlaTaco [OP] Active Member
    Scott
    North Central Florida/Ocala National Forest
    2011 Regular cab 4x4 4cyl 5spd
    Front brush bar, 4" side nerf bars, Bak Bakflip G2 bed cover, tail light cages, 3" Old Man Emu full suspention with 885 front and rear Dakar leaf springs, 3 degree rear axle shims, 8" Sound Ordinance powered subwoofer, Light Racing UCA, DeeZee bed mat
    I've noticed all the toyotec lift kits and many other kits all use an add a leaf for the rear and blocks. I found an old man Emu kit on line that has new rear leaf springs wouldn't the OME rear leaf springs be better than adding a add a leaf ? The OME complete kit I found is saying it is a 2" lift and I'm worried it will not be enough lift for the 32" nitto's I just bought.
  2. Dec 24, 2011 at 8:42 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    you can run 32's on the stock set up with no problems
  3. Dec 24, 2011 at 10:36 AM
    2011tacotrd
    2011tacotrd Well-Known Member
    Northern California
    2011 TRD offroad double cab
    Pioneer indash navigation unit, Illuminated 4x4 switch, HID heads and fogs. Black leatherette GT seat covers. toytec Ultimate lift. Now its time to mod exterior.
    Heres a pic of my toytec lift with 285/70/16 nitto trail grapplers works fine.
    [​IMG]:cool:
  4. Dec 24, 2011 at 10:41 AM
    USCoastGuard12
    USCoastGuard12 Well-Known Member
    Conner
    Beaumont,TX
    2007 Tacoma 4x4
    Black headlight, taillights, and center rear light. Custom grill, K&N intake,Revtek 3' lift,devil horn emblem,ballistic jesters
    Heres a picture of my tacoma with a 3' revtek lift with 285/70/17http://www.tacomaworld.com/forum/attachment.php?attachmentid=130417&stc=1&d=1324752074
  5. Dec 24, 2011 at 10:47 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not sure which OME coils are in the kit you were looking at , but here is my truck with 885x coils up front and Dakars in the rear .
    I got 2 1/2" up front from the coils only , no spacers , and the Dakars got me just about 3" in the rear which settled to 2 1/2" after adding my Leer cap .
    I'm running 265/70/17 Hankook MT's
  6. Dec 24, 2011 at 10:48 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Most report a 2-3/4" rear lift with the Dakars (OME springs) and the front depends on which OME spring you select. (884, 885, 886)
    Stay away from 886 unless you've added a plate bumper and winch.
    Yes, the Dakar spring pack would be superior to AAL's or blocks.
    Edit:
    Damn, that friggin Canuck and all his data beat me to it.
  7. Dec 24, 2011 at 1:00 PM
    CentralFlaTaco
    Scott
    With the 4cyl motor Pro comp said their 3" kit would sit too high in the front and would not work due to the stiffness of their front springs because they are meant for 6cy x cab and double cab. I want the truck to sit level not nose low like it currently does on the base 4x4 suspention and I want BMW type of handling not mushy like my stock springs so with the dacar OME rears which front OME springs would you suggest ? 884"s 885's or is it the shocks that dictate the handling and the springs are just lift ?
  8. Jun 2, 2012 at 8:36 AM
    wtbthree
    wtbthree Well-Known Member
    Can you say why? I'm pretty set on the OME kit with 885s, and was going to go with the Toytec TSB Add-a-leaf to get ~ 3" all around.
    I'm not in a position to drop the $ on the Dakars right now, what's the main reason splurge for the Dakar setup vs. going with the AAL?
  9. Jun 2, 2012 at 9:53 AM
    OZ-T
    Peter North
    British Columbia
    Dakars are better suited to hauling loads or towing , or for continuous loads like a cap or heavy toolbox
  10. Jun 2, 2012 at 10:10 AM
    callahansd
    callahansd Active Member
    3in Tuff Country...
    3" tuff country works fine with 33'' tires
