3" Lift Question
Discussion in 'Suspension' started by drew840, Mar 28, 2012.
  1. Mar 28, 2012 at 12:08 PM
    drew840
    drew840 [OP] Member
    So Cal
    07 PreRunner TRD
    I just bought my 06 TRD Off Road used from a dealership...
    The front end sits pretty high... Here is a picture I found online of the exact same setup I have on my truck...
    My question is:
    Is this stock lift for the TRD Off Road model??
    Or is this an add-on by previous owner??
    and what lift is it??
    I love the truck, but must say it's a little bumpy around town
  2. Mar 28, 2012 at 12:09 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Its a spacer lift put on by the previous owner
  3. Mar 28, 2012 at 12:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Spacer
  4. Mar 28, 2012 at 12:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    ^^^^ what they said
    If you take the spacer off it'll ride a lot better
  5. Mar 28, 2012 at 12:11 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Top plate spacer, easy to remove if you don't like it.
  6. Mar 28, 2012 at 3:41 PM
    drew840
    drew840 [OP] Member
    So Cal
    07 PreRunner TRD
    I love the way it looks, but sure could ride smoother.
    I gotta do some research to see if I can afford to replace it with something better...
  7. Mar 28, 2012 at 5:28 PM
    drew840
    drew840 [OP] Member
    So Cal
    07 PreRunner TRD
    So 5100's at the proper setting (2.5") would keep me at almost the same ride height the truck is now??
    and at what level upgrade do the UCA's become necessary??
  8. Mar 28, 2012 at 5:33 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The bilstein 5100s can provide 2.5" of lift using your existing coils. Or for a better ride you could run a set of OME 885 coils with the bilsteins at the Stock height setting. Will give you about 2.5" of lift also.
    The UCAs fix the low caster issue that happens when you lift the front suspension. They start being need around the 2.5" lift height, but are not required.
