3" lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScottB1414, Feb 9, 2017.
  1. Feb 9, 2017 at 10:36 AM
    ScottB1414
    ScottB1414 [OP] Member
    Scott
    2013 Toyota Tacoma 4X4 TRD Offroad
    I have an appointment tomorrow to get a 3" suspension lift put on my Tacoma. They guy asked if I wanted it higher or lower in the front and I said no so he said he would level it. Does that mean he will do 3" in the front and 2" in the back??
  2. Feb 9, 2017 at 10:57 AM
    Nate-O
    Nate-O Well-Known Member
    Nate
    PreRunner
    I'm certainly no expert on lifts but 3" in the front and 2" in the back will probably get you level, the back might sit a little higher than the front. If you go 3" in the front you are going to need aftermarket UCA's. Some people also need to drop their front diff so you don't destroy your CV shafts.
    It would probably be a good idea to search this forum about all of the various lifts and see what others have had to do when lifting 3" in the front before your appointment tomorrow. :thumbsup:
    outlawtacoma likes this.
  3. Feb 9, 2017 at 12:14 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    a 3" lift is max lift with a 4x4. I recommend doing 2.5" that way your not blowing your cv joints out constantly. you will need adjustable uca to get your alignment in spec. and a 1.5" aal in the rear should level the truck perfectly. just remember you will have to up grade rear shocks for rear lift.
  4. Feb 9, 2017 at 12:15 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    OP is getting blocks, so not an adjustable height suspension setup.
  5. Feb 9, 2017 at 12:19 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    No go on the diff drop.
  6. Feb 9, 2017 at 12:21 PM
    sbond007
    sbond007 Well-Known Member
    STEVE!
    PHX, AZ
    '12, OR, DCSB.
    NOS sticker + 100hp
    How do you know this? He said suspension lift? At least to me that means 1 thing.
    OP... NATE-O provided some good advice. Follow that.
  7. Feb 9, 2017 at 12:25 PM
    T4RFTMFW
    Because no other suspension option is ever referred to as "leveling" or "3/2."
  8. Feb 9, 2017 at 1:42 PM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    I had a 3/1 on my 05 and same ow on my14
    It sits level and have/had diff drop on both
    Used a lowrange 3/1 with front spacer and block in back. (here comes the shit storm)
    No new upper control arm
    I think it depends on what lift you go with
