3" lift, stock rims, tire size?
Discussion in 'Wheels & Tires' started by TRD11, Mar 10, 2012.
  1. Mar 10, 2012 at 7:46 PM
    TRD11
    TRD11 [OP] Active Member
    OHIO
    2011 4X4
    I am going to install a 3" lift. Leaving the stock 16" Baja wheels. I do not want to have to cut or trim anything. Are 285/75/16's a safe bet? If I need wheel spacers, what millimeter thickness? What size could I get away with without spacers?
    Thanks!:)
  2. Mar 10, 2012 at 7:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    255/85/16
    For 285/75/16 you will need wheel spacers like Spidertrax 1.25" and you will still need to trim the inner fender , remove the mud flaps and maybe trim the cab mount
  3. Mar 10, 2012 at 7:54 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    This. It's what I did
  4. Apr 25, 2012 at 3:37 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Did you HAVE to do the cab mount chop. I am running BFG 285/75/16 TA KO 3 inch Toytec lift and slightly rubbing the control arm.
  5. Apr 26, 2012 at 5:46 PM
    TRD11
    OHIO
    2011 4X4
    Do you have stock wheels? You can get 1-1.5 inch wheel spacers and that will take care of your control arm rubbing issues.
  6. Apr 27, 2012 at 12:51 PM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Ordered the spidertrax 1.25. Will be here tomorrow
  7. Apr 28, 2012 at 2:06 PM
    TRD11
    OHIO
    2011 4X4
    Nice, did you order all four or just two for up front?
  8. Apr 29, 2012 at 10:19 AM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Ordered all 4 from toytec. Cheaper than the spidertrax Web site since toytec accepts the RE coupon code. Installing today and will put pics
  9. Apr 30, 2012 at 2:43 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I have a full 3" lift front & rear with OME 885s & Dakars.
    255/85/16 BFG KM2s on 1st Gen TRDs. No trimming or rubbing.
  10. May 4, 2012 at 7:59 AM
    TRD11
    OHIO
    2011 4X4
    What is the RE coupon code?
  11. May 5, 2012 at 8:34 AM
    tmreyes1
    T-Rey
    TX
    2017 TRD
    Spacers installed and no trimming needed and no vibrations
  12. May 5, 2012 at 2:14 PM
    TRD11
    OHIO
    2011 4X4
    Looks good. What width size did you go with...1.25"? Also, what is the RE coupon code?
  13. May 6, 2012 at 5:15 PM
    TRD11
    OHIO
    2011 4X4
    Never mind, found it!
