3" lift upper arm not connecting
Discussion in 'New Members' started by TutKing2021, Aug 27, 2024.
  1. Aug 27, 2024 at 1:55 AM
    TutKing2021
    TutKing2021 [OP] New Member
    2022 Tacoma sr5 v6 4x4 access cab
    Coming to the end of my mods after the lift is complete. Maybe rims, stereo upgrade.
    Hello all,
    New here, this is my first post. So I'm lifting my 2022 sr5 3.5 4x4 access cab. 3" rough country n3 struts, 2" blocks rear with O.C n3 shocks ( I know boring right). I'm 55, owned 6 trucks Toyotas, this is my first lift. I had everything go good until I had to attach the upper arm ball joint and for some reason I can't make to two connect. I got a pray bar and once I got them connected the upper arm was smashing into the spring and it was like locked. If anything could give any adobe that would help it would be highly appreciated. Thanks
    buckhuntin-tacoma likes this.
  2. Aug 27, 2024 at 2:06 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Welcome aboard :hattip:
    try disconnecting the lower ball joint so you can do the top first then you can use a jack to jack the lower into place.
    Pics are always helpful.
    Have you tried jacking it into place?
    If that doesn’t work double check your parts are correct.
    Good luck
  3. Aug 27, 2024 at 2:17 AM
    TutKing2021
    Heys thanks for the reply. Man yeah I've tried the jack and it seems like it doesn't want to move. It's like the struts are to strong. I can take some photos in the morning, it's really late and I was just stressing. I've connected everything and disconnected everything. I have the passage side jacked up right now hoping the strut will fade down over night. When I jack the lower arm up it lifts the entire side off the jack stand.
  4. Aug 28, 2024 at 4:59 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
