3" lift vs 6" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CJM5, Dec 10, 2018.
  1. Dec 12, 2018 at 9:09 AM
    #41
    CJM5
    CJM5 [OP] Well-Known Member
    Pismo Beach, CA
    2014 Tacoma DCLB 4x4
    So leaning on just doing a BM Chop and trimming and stuffing 35s or 34s in there. I spoke with a local off-roading shop and they said if I wanted to do 35x12.5s I would need to regear. Any thoughts? This thing is slow and I don't mind it, I am really not looking for speed and rarely drive over 70 anyways.
  2. Dec 12, 2018 at 9:32 AM
    #42
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    I felt the difference with 33x12 and personally wouldn't go higher with stock gears. Everything I've read about gears and tire size on 2nd gens is that you need to re-gear for 35's.
  3. Dec 12, 2018 at 10:56 AM
    #43
    Adventuredude
    Adventuredude New Member
    Dana
    2015 double cab TRD
    Stock,for now...
    If you end up selling your 3-inch lift to go a different route I would be interested.
  4. Dec 12, 2018 at 9:45 PM
    #44
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Yep, that's at Cajun Field! :)
  5. Dec 17, 2018 at 8:11 AM
    #45
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    I've hammered many a Budwiser right where that pic was taken!
  6. Dec 17, 2018 at 1:07 PM
    #46
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    You’ll be fine with a 2” body lift, if you’re mainly a street rig, you’ll be fine. Don’t let these guys discourage you or steer you away from them.
    https://youtu.be/rE-XjJ_A0n0
  7. Dec 17, 2018 at 8:41 PM
    #47
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    with 3" coil lift is, 15mm offset, 285/70/17 KM2'S, is biggest I could fit without doing some major chopping! Without more offset, height won't matter anyways, at about 11.5" wide, tires will rub on UCA's with OEM Tacoma wheels. Something else to think about.
  8. Dec 17, 2018 at 8:44 PM
    #48
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    About the body lift, you can use brackets to raise the OEM bumper covers for looks, if you plan on installing a bull bar, or steel bumpers, brackets won't work.
  9. Jan 3, 2019 at 8:28 AM
    #49
    CJM5
    Pismo Beach, CA
    Good to know, thank you! Happened when I installed the toytec system. The rear bumper has a gap, but don't really mind that one too much, but my right bumper has about 1/2" gap that is driving me nuts.
