3" lift + what size tires?
Discussion in 'Wheels & Tires' started by Sighless, Feb 17, 2011.
  1. Feb 17, 2011 at 3:18 PM
    Sighless
    Sighless [OP] Well-Known Member
    TORONTO
    10 SR5
    guys, whats the biggest tire i can stuff without rubbing an trimming on a 2010 sr5 4x4??
    also
    im looking to buy rims and tires, i just read a thread about someone having rim fitment issues on a 17x8 im and the caliper..
    is this common?
  2. Feb 17, 2011 at 3:21 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    265 will fit. 285 you will need to trim a lil
  3. Feb 17, 2011 at 3:22 PM
    trd4life
    trd4life Active Member
    Jeff
    Somerset, Mass.
    05 4x4 double cab trd
    toytec 2.5 moto metal 17x9 285/70/17 nitto all terrain tires xm radio. custom skid plate.all in the mike cobra cb.
    i have 17x8 moto metal rims with 4.5 backspace.no problems,285x70x17 nitto terra grapplers with 2.5 inch lift minor trimming and rubbing.
  4. Feb 17, 2011 at 3:43 PM
    Sighless
    TORONTO
    10 SR5
    what offset..
    im really concerned about the rims contacting the calipers, im reading alot of people have this problem..
    has anyone with 17" rims had caliper issues?
    i have to make sure 100% they will fit as im ordering from canada and driving into the US to pick em up..
  5. Feb 18, 2011 at 9:17 AM
    SMOKED DC TACO
    SMOKED DC TACO Active Member
    Brad
    North Carolina
    2006 taco tinted smoke lights lift
    smoke tail lights, jdm fog lights, hids, 3 in lift, 20% front tint 1.3 % rear, 33" bfg km2
    if your running stock 16s, 285-75-16 mud terrains rub the upper control arm, when turning they rub the back of frame, and front of inner plastics
  6. Feb 19, 2011 at 6:21 AM
    Sighless
    TORONTO
    10 SR5
    I will be buying aftermarket rims and tires, to go with the lift.. The lift will be either a toytec spacer and leaf, or a toytec ome lift.. Both at 3"...
    So far all I have heard is 275/70/17..
    Which really sucks, because its the same size as stock... I don't any point in lifting it, if I can only gain, maybe an inch.. Just doesn't seem worth the 2' for rims and tires, and 500$ for a lift..
  7. Feb 20, 2011 at 8:52 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    With the right offset you can run 285's with minimal trimming.
    285 70 17
