3" Lift with 33's without the use of Wheel Spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco227, Mar 5, 2012.
  1. Mar 5, 2012 at 4:00 PM
    Taco227
    Taco227 [OP] Well-Known Member
    Maryland
    TRD Sport
    3" Pro Comp suspension kit, 1.25" front wheel spacers, tinted clearance lights, 4 pioneer speakers, Sony head unit, Custom Sub enclosure with 10" MTX, dash kit, wicked flow exhaust, Firestone Airbags.
    Hey everybody, I'm new to the forum. I have a 2005 Toyota Tacoma TRD Sport. I installed a 3 inch spacer lift rear AAL with 33s....pretty standard cheap lift kit. 10,000 miles later, I am replacing the front left wheel bearing... I know this was due to the lift kit, especially the 1.25" front wheel spacers. So my question is what 3" or 6" lift kit can I install that will not require wheel spacers? Also, my alignment sucks...been to the shop 4 times until I did some research and figured it's most likely the UCAs that need to be replaced.
    So... I am going to replace the UCAs with a set of LRs (on a budget).
    **I have the stock 17" TRD Sport wheels with Goodyear Duratracs.
    What 3" lift kit should I go with that will NOT require wheel spacers?
    What 6" lift kit should I go with that will NOT require wheel spacers?
  2. Mar 5, 2012 at 4:07 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    you could always go with a different backspacing (i think 4.5) and you may need to cut but you will not need wheel spacers. im pretty sure...
    as for a 6 inch lift your lookign at a drop bracket lift and you should be fine with the stock rims i blieive since you can fit 35s with a bit of trimming. Again im pretty sure
  3. Mar 5, 2012 at 4:15 PM
    Taco227
    Maryland
    TRD Sport
    When you say backspacing...do you mean installing different wheels?
  4. Mar 5, 2012 at 4:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get 255/80/17 , 33 1/4" tires , no rub with stock wheels
  5. Mar 5, 2012 at 4:20 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    yeah. but like oz said it also depends on how wide of a tire you go as well. He is running the tire size he suggested on his stock rims (looks greta oz!) with a 3 inch lift.
  6. Mar 5, 2012 at 4:27 PM
    OZ-T
    Peter North
    British Columbia
    No , I'm running 275/70/17 on stock Sport wheels which is a 32 1/2" tire , but you can run 255/80/17 which is 33 1/4"
  7. Mar 5, 2012 at 4:31 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I've had wheel spacers on my '09 (OEM sport wheels) for 3 years with no wheel bearings issues. Was running 32" tires (265/70R17) but I had TC UCA's. Many guys run aftermarket wheels with 4.5" backspacing which has nearly (within 1/4") the same effect on wheel bearings as a 1.25" spacer on stock 5.5" backspaced wheels. Basically it's converting your 5.5" backspacing to 4.25" backspacing. I think it's more likely the age of the truck being an '05 (7 years old with probably near 100k miles) combined with the stock UCA's and lift which make your caster alignment out of spec along with larger tires. I think if you fix the wheel bearings and get the LR UCA's like you said, you will be fine.
  8. Mar 5, 2012 at 5:09 PM
    Taco227
    Maryland
    TRD Sport
    Thanks Keith, thats what I was thinking. I'm going to put on the LR's and how it straightens things out a bit.
  9. Mar 5, 2012 at 5:10 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    my bad. truck still looks great:eek:
  10. Mar 5, 2012 at 5:11 PM
    Taco227
    Maryland
    TRD Sport
    So, I want a new lift kit. What's the best 3" suspension kit? I don't want to have to use the wheel spacers, and I want to run 285/70/17s.
  11. Mar 5, 2012 at 5:39 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    The best is probably gonna be Icons or Kings. Icon sells a 3" stage 1 lift thats really nice. In my opinion the best 3" would be icons coilovers in front, TC or camburg UCAs, Rear icon shocks with resi and a Dakar Leaf pack.
  12. Mar 5, 2012 at 5:40 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    old man emu is a pretty good lift. lots of guys have it. Tht what im looking to do. It all depends on what your looking to do of course.
  13. Mar 5, 2012 at 5:40 PM
    OZ-T
    Peter North
    British Columbia
    Which lift has less to do with clearing 285's than the wheels do
  14. Mar 5, 2012 at 5:43 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I think he wants to ditch the speacer lift due to early wearing of componnets that he has encountered. Ithink it was a wheel bearing. not trying to correct you cuz your right. think he was asking 2 sperate questions in his posts. I think
  15. Mar 5, 2012 at 5:51 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    well its not really early cuz he has 100k but he believes the spacer lift had to with it
  16. Mar 7, 2012 at 10:57 AM
    Taco227
    Maryland
    TRD Sport
    I'm just looking for a new lift. The spacer lift is not a good lift...shouldn't have done it. I'm mainly looking for a quality 3" full suspension lift that will not have any alignment issues or additional wear in the future.
  17. Mar 7, 2012 at 1:15 PM
    Taco227
    Maryland
    TRD Sport
    I like the Icon Stage I lift kit. It looks real nice. I drive a lot on the beaches here in Maryland. And I might off road once a month...nothing too hard core. But I'd really like a better ride. Also, I frequently carry 600-1000 pounds in the bed... any heavy duty leaf packs out there? Dakar, All Pro? anything else? What's the best for carrying heavy loads?
  18. Mar 7, 2012 at 1:24 PM
    KeithB
    Keith
    Cheshire, CT
    Any coilover (ICON, King, Fox) will be a huge improvement over the spacers especially if you combine them with aftermarket UCA designed for lifted trucks. Bilstein adjustables will be cheaper and provide nice ride but with the heavy loads you are carrying you probably will want a stiffer spring that the above coilovers will provide.
    With that said, any lift and/or larger tire is still going to cause more wear on CV's, steering components, wheel bearings, etc.. You can minimize the extra wear by getting a quality lift.
    Also, regarding the 600-1000 lbs frequent loads - you may want to think about Timbren bump stops and/or helper leaf spings/air bag load levelers and the like. They will greatly improve the ride and handling with loads.
  19. Mar 15, 2012 at 12:54 PM
    Taco227
    Maryland
    TRD Sport
    Hey guys, sorry I'm new to this site. I'm having a hard time starting a new thread.
    Anyway, I wish to get a new lift but I am on a budget. I am getting Light Racing UCA's along with either (1) front 5100 Bilstein adjustable shocks (keeping the stock coils) or (2) get 3" lift kit with Bilstein 5100 Height adjustable Coilovers. Both are on wheelersoffroad.com and Toytec lifts. Which is going to be better? I have about 110k on the truck and it runs great, but looking for a better lift rather than the spacer lift that I already have installed...
  20. Mar 15, 2012 at 3:47 PM
    lynyrd3
    Bill
    East Central Upstate NY
    I would go with Toytec .
