3" Lift with 33's without the use of Wheel Spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco227, Mar 5, 2012.
  1. Mar 15, 2012 at 3:50 PM
    Taco227
    Taco227 [OP] Well-Known Member
    Maryland
    TRD Sport
    3" Pro Comp suspension kit, 1.25" front wheel spacers, tinted clearance lights, 4 pioneer speakers, Sony head unit, Custom Sub enclosure with 10" MTX, dash kit, wicked flow exhaust, Firestone Airbags.
    Both are on Toytec's website. Just the shocks or the whole kit?
  2. Mar 15, 2012 at 3:54 PM
    lvcarguy
    lvcarguy Well-Known Member
    David
    Las Vegas
    12 4x4 DCSB Debadged
    ICON stage II lift w front coil overs 3" lift with Camburg UCA's and 1 1/2" add a leaf & ICON rear shocks, SS front and rear brake lines, TRD Exhaust, TRD skid plate, 33/12.5/17 MT General Red Labels, 17x8 Centerline wheels in matte, 6000k head and fog lights, 20% tint, 12" black shorty antenna, debadged, TRD oil filler cap, TRD radiator car, TRD shift knob, TRD all weather floor mats
    I have Icon coilovers and Icon rear shocks, camburg UCAs and a 1 1/2 add a leaf in the rear. I run 33/12.5/17 general grabber MTs, my wheels are centerline 17x8 @ 4.5 backspacing. I had to do very minimal trimming and did not have to do a cab mount chop. I also have alteast an inch left on the coil overs.
    The lift is pretty close to 3 inches in the front.
    But it wasn't the cheapest route out there.
  3. Mar 15, 2012 at 4:06 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    I replaced both my front wheel bearings around 60-70k. I have only had stock rims and max 32" tires the whole life of the truck. Possibly it was just time for them to shit the bed and not a result of your tires/spacers.
  4. Mar 15, 2012 at 4:39 PM
    tacosunday
    tacosunday GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Cambridge UCAs?
  5. Mar 15, 2012 at 4:45 PM
    lvcarguy
    David
    Las Vegas
    sorry camburg, was typing a little fast
  6. Mar 15, 2012 at 6:27 PM
    Conviction11
    Conviction11 Busting Asphalt
    J
    South Carolina
    I've got the pro comp 3" lift which pretty much is the cheapest way to go.
    I didn't expect to much from it, since so many people put it down (especially on this site) but I've been very happy with it. I'm running 285/70/17's with a 4.53 back spaced rim.
    I've already cut a lot of plastic out and I'm hitting the frame when I hit a bump while turning sharp. just a bit, but I'm going to do the frame chop here in the next 10 days or so. Should be good to go.
    The reason I'm rubbing is because I have KM2's. I think I could have got a less aggressive tire and wouldn't have near as much rub.
  7. Apr 17, 2012 at 3:21 AM
    Mendoman
    Mendoman Well-Known Member
    South Lake Tahoe
    2008 SR5 DCSB / 22 TRD OR DCSB
    6112/5100 RXT Option 1
    Lots of good info here! Thanks for all the input. I just need to have one thing cleared up. In theory, running sport rims (5.5 backspacing) with a 1.25" spacer would accomplish the same thing as buying new rims with 4.25" bs?
  8. Dec 4, 2013 at 12:05 PM
    FlintsTaco
    FlintsTaco Member
    Tropix
    Sonoma County
    2013 Silver 4x4 Sr5
    20% Tint all Around Bilstein Adjustable lift kit with 5100 shocks LR UCA BAMF Cab Mount Chop MagnaFlow Exhaust 1.5 TSB AAL + 1" Block U-Bolt flip Kit
    I just finished installing the Bilstein Adjustable Lift Kit with 5100 shocks and LR UCA. In the rear, I did the 1.5 TSB AAL. Measuring the front from center hub to bottom fender I'm at 22.5", not a full 3" at 23". I have the C clipon the second adjustment from the bottom with the 1/2" spacer but still a 1/2" shy.
    Toytec states, "3" average lift is achieved with coils and settingthe shock adjustment on the second C clip setting from the bottom, Double cab models may require top plate spacers for full 3" lift."
    I understand it states "average" but if you take away the1/2" spacer I’d be a whole 1" off?
    So after spending my hard earned money and time installing the lift I ordered rims and tires, 285 65 18 Toyo AT II on 18" ProComp 5001. Looks beautiful but rubs horrible when turned and going in reverse on the inside-back of the front fender. So bad it cracked it. My Friend is running the same set up but he kept the stock coil, put the C-clip on the top adjustment without new UCA and he rubs just a bit at full turn in reverse, not enough to notice.
    What should I do, any advice?
  9. Dec 4, 2013 at 1:19 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    What is the backspacing on your wheels. Are they stock or aftermarket. Optimal is 4.5" bs. Spidertrax wheel spacers on stock wheels will give you close to 4.5" bs. Less backspacing and your tire will stick out of the fender further and rub the wheel well plastic. More backspacing and your tire will be tucked in more but may rub the frame more. If you still rub after correcting backspacing, cut some plastic away and maybe cut the cab mount.
  10. Dec 10, 2013 at 10:27 AM
    FlintsTaco
    FlintsTaco Member
    Tropix
    Sonoma County
    2013 Silver 4x4 Sr5
    After taking a deep breath I realized the wheel, the tire shop Ordered me wasa 18x9.5, way to wide!
  11. Dec 12, 2013 at 3:25 PM
    FlintsTaco
    FlintsTaco Member
    Tropix
    Sonoma County
    2013 Silver 4x4 Sr5
    Wouldn't that just make them stick out even Further? I’ve narrowed down my decision to the ,
    Procomp 7032, 18x9 00-Offset5-Backspacing
    Stealth6, 17x8.5 Offset -10mm 4.3-Backspacing
    I like the Stealth 6 wheels butt after talking to Vin from www.stealthcustomseries.com/‎,he said I’ll have to do a CMC. My Rig is pretty Knew I don’t want to startchopping away at shit. There’s a SCS Stealth 6 New 18" Wheel **Group Buy** for a , 18x9 00-Offset5-Backspacing. But who knows? That pretty much puts back to the Procomp?EEERRRRR…….
