3" Lift with 33's?
Discussion in 'Suspension' started by FixItTicket, Jun 16, 2013.
  1. Jun 16, 2013 at 9:23 PM
    FixItTicket
    FixItTicket [OP] Member
    Kyle
    San Diego, CA
    So earlier today I was wanting to get myself a nice 6" suspension lift on my DCSB tacoma but after doing a lot of research I changed my mind and would rather get some really nice coil overs with UCA nice rear shocks and leaf pack maybe some deavers or all pro. My question is would I be able to fit 33's with that set up without rubbing?
  2. Jun 16, 2013 at 9:24 PM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    yes, just make sure you get enough offset on the wheels.
  3. Jun 16, 2013 at 9:28 PM
    FixItTicket
    Kyle
    San Diego, CA
    okay awesome! Would you recommend some spindles with that set-up or do you think that's just fine if I go with a camburg kit as far as off roading it goes?
  4. Jun 16, 2013 at 9:30 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    You should be able to fit 33's. REMEMBER Spindle lifts are only for 2wd, idk if you are 4x4 or not. Smart choice about going with coilovers and UCA's.
  5. Jun 16, 2013 at 9:33 PM
    FixItTicket
    Kyle
    San Diego, CA
    yea I saw this tacoma at a dealership with a 6" lift, fell in love with the look didn't realize that the 6" db is only good for the look and then read some stuff about how amazing the coil over uca set up is for offroading. I have a 2wd would you recommend spindles like the TC ones or should the coil overs and UCA be enough?
  6. Jun 16, 2013 at 9:42 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    I’m not 100% sure but i think some one makes a 4” llift spindles. maybe it’s 4.5”
    I also think that most the hate for 6” lift comes from 4wd guys, because you actually lose ground clearance with the drop bracket. I like the looks of the 6”, but i want to really get into off roading(if i could get the cash to do so) and the 3” is better for 4wd guys wanting to off road a lot/ really hard. But since you are 2wd you don’t have that.
    If i was you and had a 2wd, I’d get a 6” and 35”s. and sounds like thats what you really like the looks of, so why not do it exactly like you want?
  7. Jun 16, 2013 at 9:45 PM
    FixItTicket
    Kyle
    San Diego, CA
    I thought the 2wd had drop brackets does it not with a 6" lift?
    and also because I read through this whole thread
    http://www.ttora.com/forum/showthread.php?t=132096
    and they bagged on the 6" lifts throughout the whole thing said the coil overs with UCA are the better way to go as far as offroad performance is concerned.
  8. Jun 16, 2013 at 9:45 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Stick with just coil overs and UCAs.
  9. Jun 16, 2013 at 9:50 PM
    FixItTicket
    Kyle
    San Diego, CA
    could you elaborate a little more on why that set-up is better because I have no idea why it's better other than that's what everyone is saying. btw just in case nobody knows I have a 2wd...
  10. Jun 16, 2013 at 9:50 PM
    redtacoma88
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
  11. Jun 16, 2013 at 9:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your not gaining anything really with spindles..some front end clearance I suppose.
    Just UCAs and a nice CO will ride better.
    But if your not into offroading or having looked t long travel yet(if you do you will want it haha) then go for the spindles.
  12. Jun 16, 2013 at 9:55 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    no don’t think so! the drop bracket drops/lower the front diff to keep the right angles on the drive shafts.
    also coil overs are kinda the way to go. but agin i don’t know anything about spindles.
  13. Jun 16, 2013 at 9:56 PM
    FixItTicket
    Kyle
    San Diego, CA
  14. Jun 16, 2013 at 10:47 PM
    Tkucera
    Tkucera New Member
    Hello
    I have a 2.7 litre 4 cylinder 2wd 2012 toyota tacoma I want to put it on a lift with 33 in tires but I only see lift kits for the prerunner 2wd wich isn't my truck was wondering if the lift would work on mine even though it isn't a prerunner
  15. Jun 16, 2013 at 10:49 PM
    Tkucera
    Tkucera New Member
  16. Jun 16, 2013 at 10:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    There are tons if of 4wd lifts. Your not looking in the right places..
