3" lift with heaver springs? no AAL
Discussion in 'Suspension' started by burnthesnikle, Aug 18, 2009.
  1. Aug 18, 2009 at 5:28 PM
    burnthesnikle
    burnthesnikle [OP] Active Member
    is there something....been reading the shit out of all the old threads haven't really found a answer...anyone with pictures? if you have done something different...
    cut wood for heat and always have a load...
  2. Aug 18, 2009 at 5:32 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Custom Leaf packs maybe? What do you have now?
  3. Aug 18, 2009 at 5:33 PM
    burnthesnikle
    2006...3" spacers in front and AAL in back with the 3pk leaf
  4. Aug 18, 2009 at 5:35 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    And the aal isnt sufficient for your loading?
  5. Aug 18, 2009 at 5:37 PM
    burnthesnikle
    not really...Oak is heavy...and when loaded down folds the springs back alittle where the end of the AAL's are on the stock springs...if that makes sense
  6. Aug 18, 2009 at 5:40 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I dont load up my truck too often. I have a 3" All Pro leaf pack but thats for better flex and offroading so Im not sure where to send you. But It might be a good idea to look into some bumpstops such as Timbrens.
  7. Aug 18, 2009 at 5:45 PM
    burnthesnikle
    well i do alot of offroad too...so i'm tore a little on what to do...
    what is the rating on those springs? good as stock?
  8. Aug 18, 2009 at 6:05 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Hmm im not too sure. But they are not for carrying loads. Of course you can but they would sag a lot. Let some others chime in.
  9. Aug 18, 2009 at 7:11 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    From what I understand, the dakar leaf pack is supposed to be really good for sag issues. They'll give you 2.75'' of lift, which may or may not be for you. Not too many people on here have them, but I'm sure the ones that do will see this thread.
  10. Aug 19, 2009 at 9:34 PM
    eganx
    eganx Well-Known Member
    Kingston WA
    99 Tacoma
    We(I work at skyjacker) make some rear leaf springs fort your app. TCR25S is the individual spring part #, the come in our 3" kit.
    I'm fixin to lift my tacoma using a pair of the springs myself
  11. Aug 20, 2009 at 5:46 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Get some leaf spring helpers
  12. Aug 20, 2009 at 2:46 PM
    burnthesnikle
    that says it's for a 1996 tacoma...i have a 2006
  13. Aug 20, 2009 at 7:13 PM
    burnthesnikle
    found the answer...Skyjacker does make a spring pack for a 3" lift...
    now does a superspring work as well?
  14. Aug 20, 2009 at 7:16 PM
    Eesh
    Eesh Well-Known Member
    Canada
    2025 Tacoma Limited
    Dakar 10 leaf pack. End of Story. Greater payload. 2.75 inches of lift. and won't start squeaking like alot of leaf packs do.
  15. Aug 21, 2009 at 5:24 AM
    burnthesnikle
    where did you find these? cost? stiff ride? under axle?
    the lift in front of my truck is 3"...so if i add these it will be 3/4" higher in back?
    thanks
  16. Aug 21, 2009 at 7:54 AM
    Eesh
    Canada
    2025 Tacoma Limited
  17. Aug 21, 2009 at 8:00 AM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
  18. Aug 21, 2009 at 10:46 AM
    burnthesnikle
    well i'm not sure what to go with yet....
    either: Skyjacker...gives me a level ride 10% more payload
    EMU Dakar...7 pk...more payload...but what ride height? have to call on these...not sure if they are over or under axle?(called them)
    i don't want to and to my ones i have now...don't trust them
    i'm thinking Skyjacker with supersprings if possible...
    like i said before...i'm always hauling something...and mostly wood
    thanks for the Help
  19. Aug 21, 2009 at 4:39 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    First of all with 3 inches up front and 3 inches in the rear you will have a terrible rake. I have 5" up front and 3" in the rear to get my truck level. But whatever height you go with in the rear, contact Deaver suspension. They will build you a custom leaf pack to whatever specs you want. You can tell them how much lift, how much towing and hauling.
    http://www.deaverspring.com/
  20. Aug 21, 2009 at 4:55 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    put some air bags in the rear they work great
