3" Lift
Discussion in 'Suspension' started by Flmxrider, Jan 31, 2011.
  1. Jan 31, 2011 at 5:48 PM
    Flmxrider
    Flmxrider [OP] Active Member
    Tampa
    99' Tacoma Prerunner
    5100 Bilsteins/Eibach Coils,2" AAL, 265/75/16 Duratracs on Procomp Steelies, Baja Bumper, 5%Tint.
    I have a 99' Prerunner and I'm trying to figure out what 3" lift I should get. I don't have enough to spend on coilovers, but eventually plan on upgrading to those. I've read some pretty bad things about spacer lifts so I don't know if thats a good choice, even though I don't offroad. What's the best option out there besides coilovers?:confused:
  2. Jan 31, 2011 at 6:11 PM
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    Check toytec lift they have nice stuff also on 4wheelingonline have a procomp 3" for 467 bucks ...
  3. Jan 31, 2011 at 6:57 PM
    Flmxrider
    Tampa
    I looked at the toytec lifts and those are pretty reasonable. I'll probablly go with the spacer for now and either AALs in the back or blocks. Which is better out of those? Also do I need extended rear shocks if I do that? If anyone of you guys can help me with that, thanks.
  4. Jan 31, 2011 at 6:58 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    Old Man Emu! High quality, and that's what I have.
  5. Jan 31, 2011 at 6:59 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    AAL's are a better choice than blocks. Blocks tend to promote axle wrap. I'd avoid spacers in the front also.
    You won't need longer shocks in the rear.
  6. Jan 31, 2011 at 7:03 PM
    Flmxrider
    Tampa
    Yeah I'm trying to avoid getting a spacer lift. I've heard good things about OMEs but what about If I did 5100 Billies front and back with a top spacer in the front. How does that work?
  7. Jan 31, 2011 at 7:07 PM
    KPT
    09 Prerunner
    Why the top plate spacer on the 5100's?
  8. Feb 1, 2011 at 4:11 AM
    Flmxrider
    Tampa
    Nevermind about the top spacer. So you can set the Bilsteins at a certain height or how does that work?
  9. Feb 1, 2011 at 5:32 AM
    KPT
    09 Prerunner
    You can set them at 0.85", 1.75" or 2.5". Each setting preloads the stock springs slightly more.
  10. Feb 1, 2011 at 7:59 AM
    Flmxrider
    Tampa
    OKay cool so then should I do AALs in the back? or can you set the back?
  11. Feb 1, 2011 at 8:14 AM
    KPT
    09 Prerunner
    AAL. The rears are not adjustable.
  12. Feb 1, 2011 at 11:54 AM
    Flmxrider
    Tampa
    Thanks for the help.
