3" Lift
Discussion in 'Suspension' started by norcalbb11, Sep 17, 2008.
  1. Sep 18, 2008 at 7:50 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  2. Sep 18, 2008 at 7:55 AM
    norcalbb11
    norcalbb11 [OP] Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    nice, so i get those and put it on the higher setting to lift it a bit would it me a pretty rough ride? and if i go with the spacer would it be a smoother ride with the shocks being back to stock hieght? i wonder if it would count as a lift if i got these shocks and put them on the higher setting haha thinking insurance right now
  3. Sep 18, 2008 at 7:58 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its gonna definitely level the truck...set them at the 1.75 setting. ride will still be ok.
  4. Sep 18, 2008 at 8:14 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    your like my truck guru haha, i might just start off with that because either way its going to be a better shock then the sport suspension i have on now and i dont have to mess with insurance
  5. Sep 18, 2008 at 8:15 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep...definitely a better shock...gonna ride awesomely man!!:D
  6. Sep 18, 2008 at 8:17 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    haha i like the word, but yeah ill look into that, and do you keep the stock spring in front?
  7. Sep 18, 2008 at 8:58 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep...front coils are fine!!
  8. Sep 18, 2008 at 9:08 AM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    nice seems like the way to go for now before i put a lift on it, how long would it take for a mechanic to do this you think?
  9. Sep 18, 2008 at 9:40 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the shock install..........probably around 2 hours..........i think.
  10. Sep 18, 2008 at 1:19 PM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    oh nice nice thats not to bad ill probably get raped by the mechanic and he will say like 4 hours or something
  11. Sep 18, 2008 at 1:59 PM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    why did you only have them for a brief period?
  12. Sep 18, 2008 at 2:15 PM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    yeah im looking to get 3" on my 09 but looking into different ways of doing it, so far les schwab would just to a revtec 3" spacer with my stock suspension
  13. Sep 18, 2008 at 2:46 PM
    norcalbb11
    Cali
    09 Taco Sport 4x4
    how high is that 07 you got there?
  14. Sep 18, 2008 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have your 886's sagged at all? My 885's have only sagged 1/4" since I have had them, 23,000 miles. :)
  15. Sep 18, 2008 at 4:47 PM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im running 32" tall tires, and my front is 38.5" from ground to bottom of fender flare.
  16. Sep 18, 2008 at 6:43 PM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    So If I went to 33's I'd be right at your height. Or if I used the 1/2" spacer they say you need for the 3" lift. :)
  17. Sep 18, 2008 at 6:56 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im running 285/60/18's which is a 32" tire. 31.6 or something like that.
  18. Sep 18, 2008 at 7:10 PM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OME had some issues with their springs sagging prematurely. I spoke with them before I got my 885's and they assured me that the springs have been made to not sag like they used to. They shouldnt sag any more than anyother spring.
  19. Sep 28, 2008 at 8:34 PM
    #39
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    this is a great thread... Learned alot.
  20. Sep 28, 2008 at 10:19 PM
    #40
    neontrail
    Idaho
    Are these good quality to buy???
    2005-2008 Toyota Tacoma 4x4 and 4x2 Trucks
    CCM Offroad and Performance has designed and built the best quality and strongest lift kit on the market. This kit will level the front of your Toyota Tacoma Truck by lifting the front up 3 inches.
    --- 1/4" Steel which is CNC Laser Cut (NOT plasma or flame like other kits) for a very tight tolerance fit.
    --- 1/4" Wall High Strength Spacer Tubing for a very high strength unit.
    --- OEM Style Grade 10.9 Pressed in Studs (NOT welded in bolts) This keeps the bolts from weakening during the weld process.
    --- Turn Table High Frequency Pulse Welded. Insures for proper penetration of all the weld area without the need for starts and stops.
    --- Powder Coated semi gloss black for a great looking long lasting durable finish (NOT just rattle can painted or sprayed with automotive undercoat.)
    --- Complete and easy to follow installation instructions for a simple straight forward install.
    --- LIFETIME GUARANTEE!!!! For questions telephone us at 805-464-0505 or email us at info@ccmoffroad.com.
    #40
