3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TexRGV, Feb 4, 2016.
  1. Feb 5, 2016 at 6:13 AM
    #121
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Have you thought of adopting (me)...?
    12taco likes this.
  2. Feb 5, 2016 at 6:29 AM
    #122
    TexRGV
    TexRGV [OP] Well-Known Member
    Johnny
    Rio Grande Valley
    2015 Tacoma TRD Off Road
    265/75/16 wheels & tires 887, from Headstrong Off Road AAL and blisteins rear
    Hey 12 Taco u think I should order it with AAL or 1.5 block for rear? What wks best? Don't have a camper or anything.
  3. Feb 5, 2016 at 6:30 AM
    #123
    TexRGV
    Johnny
    Rio Grande Valley
    Wish I could, I'm sure that would b an extra 2 grand
  4. Feb 5, 2016 at 6:31 AM
    #124
    TexRGV
    Johnny
    Rio Grande Valley
    Think I'm gonna place order today.
  5. Feb 5, 2016 at 6:40 AM
    #125
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Blocks are simple.....They aren't the greatest way to lift a truck, but so long as they aren't more than an inch or so, not a lot of harm.....AAL's will eventually cause leafs to flatten out. I've broke 2 leaf springs in the past with AAL's. Personally, I'd avoid BOTH if the cost of a complete leaf pack is in the budget. Blocks and AAL's are bandaids.
  6. Feb 5, 2016 at 7:02 AM
    #126
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    From nearly every place I have seen including HS you pay more for the OME shocks and therefore they are generally more expensive.
  7. Feb 5, 2016 at 7:03 AM
    #127
    GYOAZ
    GYOAZ Well-Known Member
    Gary
    Tucson, AZ
    2015 Tacoma SR5 4X4 MGM access cab
    Billies and Eibachs, Camburg BJ UCAs, Demello hybrid sliders SOS HC rear bumper, SOS front bumper, Warn M80000, fully armored, Safari snorkel, No-slip locker, diff breather, bumper and roof mounted light bars, onboard Viair, 275/70 17 BFG ATs, and a badass sound system.
    Good point about the rust under the yellow paint. I went with billies due to the longer extended length. I personally don't care if my ride is a little rougher since it's a truck. But people have gone on about how much nicer the ride is with ome. With no extra weight up front I was suggesting ome due to the squishier ride, not because mixing is bad. I mix red bull and vodka all the time and they're different brands.
  8. Feb 5, 2016 at 7:14 AM
    #128
    Mr Salty
    Hermmy
    Lots of chrome
    AALs help reinforce the factory packs so they actually help prevent them from flattening out. Blocks actually accelerate this process; but more so blocks over 2" thick. The benefit to an AAL aside from helping to support the factory packs, is their thickness.
    Edit made below to explain things better... read retarded before
    EXAMPLE: Where as a 2" block is 2" thick adding to the thickness of the pack, a 2" lift AAL is only about 1/4" thick. The end result with the block is it requires 1.75" more extended length out of the shocks meaning you will fully extend the shocks easier with the blocks vs the AAL. The good thing about the block is that they have no impact on the quality of ride like an AAL does; the AAL slightly increases the spring rate, which isn't a bad thing considering how weak the factory packs are.
  9. Feb 5, 2016 at 7:19 AM
    #129
    TexRGV
    Johnny
    Rio Grande Valley
    I'll see how much more it is to add leaf pack if . If it's a lot I'll just do 1 1/2 blocks.
  10. Feb 5, 2016 at 7:24 AM
    #130
    Mr Salty
    Hermmy
    Lots of chrome
    :laugh: your liver is going to hate you for mixing those.
    Yeah my tone was off a bit in my initial response, probably came off like a dick after re-reading :oops:
    I just wanted to provide some insight on the two. As far as the ride goes for me its hard to tell the difference between them. So much of this comes down to ones perception and slight differences in trucks. Compression wise the OMEs might be a bit softer, I know the soft ride ones are. Rebound wise the Bisteins rebound quicker over the OME so that in itself can influence the ride.
  11. Feb 5, 2016 at 7:38 AM
    #131
    Mr Salty
    Hermmy
    Lots of chrome
    Now hears my deal with leaf packs. They are typically quite a bit firmer than the factory ones. For some people this is a good thing and can use the extra steel back there, but for a lot of people who always have an empty bed and who primarily use their Tacomas to commute back and forth to work and almost never go offroading, the factory packs are just fine. Toyota basically designed these packs surrounding that population of people simply because that's how the majority of Tacoma owners use these trucks.
    In other words if you like the quality of ride as is and don't want it substantially stiffer in the back, maybe avoid replacing the packs.
  12. Feb 5, 2016 at 7:43 AM
    #132
    TexRGV
    Johnny
    Rio Grande Valley
    Does anyone know if u can use the stock rear shocks with Dakar springs?
  13. Feb 5, 2016 at 7:49 AM
    #133
    TexRGV
    Johnny
    Rio Grande Valley
    10-4, so just go with block and I should b fine right?
  14. Feb 5, 2016 at 7:55 AM
    #134
    TexRGV
    Johnny
    Rio Grande Valley
    AAL it is then, thanks
  15. Feb 5, 2016 at 8:04 AM
    #135
    Mr Salty
    Hermmy
    Lots of chrome
    You can, but I would not recommend it. The rear shocks in these trucks are the limiting factor for droop anyways, they basically serve as limit straps. Dakars are thicker so they will fully extend the shock quicker, so that's one thing, but its more the spring rate of the Dakars compared to the factory packs. Due to their spring rate they will extend at a greater force over the factory packs in which case the rebound of the shocks will have a harder time fighting the extension of the packs and so once the shocks hit their limit they will undergo greater impact (run on sentence from hell).
    Hope this helps
    Thats a decision you will have to make based on use/needs/expectation.
  16. Feb 5, 2016 at 8:19 AM
    #136
    TexRGV
    Johnny
    Rio Grande Valley
    Thanks I'll just go with AAL.
  17. Feb 5, 2016 at 8:45 AM
    #137
    TexRGV
    Johnny
    Rio Grande Valley
    Ok talked to Marie again, gonna order the following:
    Blisteins 5100 kit
    Coil 2887 which is OME 887
    Struts assembled
    LR UCA's
    AAL for rear
    Total 1097.99
    Is that a good set up or no? Before I place the order.
  18. Feb 5, 2016 at 8:54 AM
    #138
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Very common set up that seems to make everyone happy! You should be just fine!
  19. Feb 5, 2016 at 8:57 AM
    #139
    TexRGV
    Johnny
    Rio Grande Valley
    Thanks bluegrass
  20. Feb 5, 2016 at 9:20 AM
    #140
    TexRGV
    Johnny
    Rio Grande Valley
    Order complete,
    Thank everyone for your input, all info was good, I'll post pictures when all is complete.
