3" not tall enough 6" a little to much... not sure!!!
Discussion in 'Suspension' started by yodalove, Nov 23, 2011.
  1. Nov 23, 2011 at 8:35 PM
    yodalove
    yodalove [OP] Member
    jake
    tennessee
    06 trd dbl cab 4x4
    bone stock for now
    * 06 tacoma trd dbl cab 4.0L * ( wanted one since i was 16 )
    Fisrt off i love the truck more than i thought i could. drives amazing with lots of power from that 4.0 liter. the problem im having is deciding what to do about lifts. i want a little more that 3" (i think) but i dont have the money to do everything that a 6 " lift and 35's requires. so i guess my question would be is there a combonation of blocks coils and shocks that would give me 4" or a little more without spending 1000 $ on the lift. not a serious wheeling truck but will go in the woods from time time so needs to be pretty functionable..
    looking to put beefy 33 x 12.50 on it with enough gap to look aggresive...any advice or examples of set ups would be so very appriciated!!!!!! thanks guys
  2. Nov 23, 2011 at 8:38 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    RCD 4.5 inch lift. It's kinda right in the middle of 3 and 6.
  3. Nov 23, 2011 at 8:59 PM
    yodalove
    jake
    tennessee
    06 trd dbl cab 4x4
    bone stock for now
    that would be nice if it werent about a grand over my budget haha... i mean i know the standard 3" lifts are reasonable i was just hoping there was another option for a little bigger .. if not then i guess ill have to get over it ..
    on a side note this is my first post and im stoked to get a reply that fast so thanks man..
  4. Nov 23, 2011 at 9:04 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Stacking lifts to go over 2.5-3" will kill your suspension, and put you in danger of serious damage.
    Just take your time and save up the $$ and do some research...im fairly certain if you read into db lifts you'll stay with the 3" :D
  5. Nov 23, 2011 at 9:11 PM
    rmahoney2013
    rmahoney2013 Well-Known Member
    Robert
    California
    Speedway Blue Tacoma
    Go 3" and trim you could fit 35s. See what you want in person too. Could change your thoughts... Pictures look good but can be deceiving
  6. Nov 23, 2011 at 9:12 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    I had 4" of lift at one point and wasnt to smooth haha.
  7. Nov 23, 2011 at 9:17 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Since you are 4x4 the only way to go over 3" of lift would be a drop bracket lift. As far as I know the only company to make a 4.5" lift is RCD. Drop bracket lifts require cutting crossmembers and lose ground clearance versus a 3" lift. You can run 33/12.5 tires with a 3" lift and some minor trimming.
  8. Nov 23, 2011 at 9:20 PM
    yodalove
    jake
    tennessee
    06 trd dbl cab 4x4
    bone stock for now
    i figured there was a reason so many people go with the three and the more i look the more it holds true... i have had a few jeeps that were 4" or more and had no drivetrain problems but i guess thats not this case with tacos... which is fine its the truck ive wanted for a long time. I dont want 35's anyways so i guess the question now is whats the best set up on the 3 " lift... factory feeling ride isnt the biggest concern.
  9. Nov 23, 2011 at 9:23 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    You sir just asked the right question.
    Take a look at the "Lift" link in my signature. Tons of good info there. You can build a quality 3" lift many different ways. It all depends on your budget.
  10. Nov 23, 2011 at 9:28 PM
    kmok
    Kyle
    Columbus, Ohio
    How much are you willing to spend? I would check out the OME lift setups and look into getting new ucas as well. Stay away from blocks and spacers.
  11. Nov 23, 2011 at 9:30 PM
    yodalove
    jake
    tennessee
    06 trd dbl cab 4x4
    bone stock for now
    so i scanned through your build pics and the one after you said you went to 295's.. are you still on the 3" pro comp lift only or had you done something else at that point... nice srh sticker btw!
  12. Nov 23, 2011 at 9:33 PM
    yodalove
    jake
    tennessee
    06 trd dbl cab 4x4
    bone stock for now
    yeah i had no plans for either ... honeslty i was hoping to have around 1500 in the lift tires and wheels ... if thats not even in the ball park i guess i'll have to bite a bullet or two haha.. and thanks for the link and all the help
  13. Nov 23, 2011 at 9:36 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Just don't post asking how to get your mpg back up once you done the lift and tires, because you can't, it will tank.
  14. Nov 23, 2011 at 9:39 PM
    yodalove
    jake
    tennessee
    06 trd dbl cab 4x4
    bone stock for now
    ill deal with it lol. that thread on lifts is amazing btw ...
  15. Nov 23, 2011 at 9:42 PM
    Blacktacoma23
    Denver/Phoenix
    Yeah I still had the pro comp lift, and I still run the rear part of the kit.
  16. Nov 23, 2011 at 11:15 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    OME 885, top spacers. OME shocks. AAL kit.
    Best all purpose general set up. Throw in some UCAs and you're set.
