3 older tires 2 newer tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew61987, Jun 18, 2019.
  1. Jun 18, 2019 at 11:57 AM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Due to un-repairable tires and thanks to America's Tire warranties, I now have 2 brand new ST Maxx tires (235/85/16, 18.5/32 tread) and 3 with about 9/32 tread remaining. 9.5/32 difference.
    Should I match front left with rear left (and F.R. with R.R.) and have my spider gears always slowly spinning even when driving in a straight line?
    Or should I have front left match with front right (and R.L. with R.R.) and have constant front-to-rear driveshaft differentiation while in 4x4? I drive about 100 miles a month in 4x4 always on dirt.
  2. Jun 18, 2019 at 12:11 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    New tires go on the same axle
    Alexely999 likes this.
  3. Jun 18, 2019 at 12:14 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The shops I’ve been going to have been putting the new (pair of) tires on the rear axle.
  4. Jun 18, 2019 at 5:55 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Many reputable tire stores won't sell you less than 4 tires for a 4X4. Especially with that much difference in wear. If it were my truck I'd buy 2 more new tires and try to sell the others to someone else. If you don't you'll never get out of the cycle of having 2 new, and 2 old tires on there.
    But if you insist the new tires go on the back. And I'd only operate it in 4X4 in extreme emergencies for as short a distance as possible. You'll essentially have 4.11 gears on the rear axle and 3.73's on the front.
  5. Jun 18, 2019 at 7:44 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This for sure ^ also ALL of them need to be the same size on a 4x4.
  6. Jun 18, 2019 at 9:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OP said: " I drive about 100 miles a month in 4x4 always on dirt.".
    Put them on the same axle and don't worry about it. Not enough difference to matter.
