3 or 4 leaf pack with 2010 rear tsb?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teej, Dec 23, 2010.
  1. Dec 23, 2010 at 7:20 AM
    teej
    teej [OP] Active Member
    NH
    '10 TRD Sport Dbl Cab
    OEM bed mat, Extang Trifecta tonneau, XM satellite radio, remote start, bull bar, hella 500s
    i searched this topic but didn't find much. i have a 2010 trd OR sport with a 3 leaf pack in the rear. I know of and have read the rear leaf spring tsb for previous years. my truck has a 3 leaf pack and i have heard that if you have 3 you can qualify for the tsb to get done. is that right?
    i wouldnt quite say my truck has a harsh ride but i do always have about a 150 lbs of tools in my truck and the roads i drive on are warped and full of pot holes. ( i live in new england). so those of you have gotten it done, did you go from a 3 leaf and they installed a 4 leaf pack? or did they replace the 3 leaf with another 3 leaf pack with different compression ratings?
  2. Dec 23, 2010 at 7:32 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    The three leafs is the standard leaf pack. The TSB will be a four leaf pack. I had mine done last year. If the truck hits the bump stops they should do it for you depends on the dealer I guess. There are lots of threads just do a search for leaf spring tsb and you'll find lots of threads.
  3. Dec 23, 2010 at 4:18 PM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    TSB will give you 4 leafs and about an extra 1" of height.
  4. Dec 23, 2010 at 4:35 PM
    TRD4x4JIM
    TRD4x4JIM Well-Known Member
    JIM
    Hartland U S A
    2010 toyota tacoma TRD 4X4 OFFROAD
    4.0L V6 DOHC 24V 236hp 5 Speed Auto trans Part Time 4x4 2 Speed Transfer case Auto LSD, 16" TRD wheels, VSC TRAC TPMS, TRD OFF-ROAD EXTRA VALUE PACKAGE.... OFF-ROAD TUNED Suspension, Bilstein Shocks... Locking Differential.. VSC + ATRAC , HAC, DAC, SKID PLATES TOW HOOKS POWER INVERTER,FOG LAMPS , WINDOW TINT, RUNNING BOARDS ROOF RACK DOOR SILL PROTECTORS hot plug for my cell phone... A R E camper shell
    The TSB # is (t-sb-0305-08) Rear spring harsh ride. You can read all about what Toyota will do for your truck.... My 2010 trd is going in on Monday for the ride tsb and for vibs. at and round 20 to 40 mph sounds like a pipe is hitting the frame... :eek:
  5. Dec 27, 2010 at 8:25 AM
    TRD4x4JIM
    JIM
    Hartland U S A
    I am at riverside Toyota. Working on this tsb. They been giving me a hard about not needing it done till I took out the photos
  6. Dec 27, 2010 at 10:46 AM
    TRD4x4JIM
    JIM
    Hartland U S A
    my truck is getting the 4 spring pack, tsb for vibs, trans shifting tsb, ecm flash, will be done on Friday
  7. Dec 27, 2010 at 2:28 PM
    southpier
    southpier Well-Known Member
    is this something i need to worry about in a '11 model? the 3 leaf springs almost curl up (reverse arch) and all i have is a cap & moved the spare up into the bed, so it's not a weight issue.
    thanks
  8. Dec 27, 2010 at 2:48 PM
    JDeLuca
    JDeLuca Well-Known Member
    Joe
    Staten Island NY
    2013 TRD Sport MGM
    TRD Cat Back Exhaust, Bed mat, Weather Techs wet okole seat covers
    Don't the dealers get paid by Toyota for this? Like warranty work? Wonder why some dealers do not want to do the work.
  9. Dec 27, 2010 at 3:27 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yes they get paid the warranty rate.
  10. Dec 27, 2010 at 4:34 PM
    TRD4x4JIM
    JIM
    Hartland U S A
    I tow a trailer with a atv i needed this done... DO or WILL you tow a trailer that is the ????? when mine gets done on Friday i will order 5100's lift....
  11. Dec 31, 2010 at 5:03 PM
    TRD4x4JIM
    JIM
    Hartland U S A
    I just returned from Toyota from having my spring pack change from 3 to 4 leaf spring pack WHAT A different ride now my truck rides so good!!!!
    It was OK with the 3 leaf springs but now it is more firm... I like it a lot....
    :D
