3" or 6" lift for towing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jmoney317, Mar 11, 2012.
  1. Mar 11, 2012 at 7:01 AM
    Jmoney317
    Jmoney317 [OP] Member
    Knoxville TN
    10 Tacoma
    i have a 2010 DC 4x4 and i tow a 4500lb wakeboard boat. looking to get a lift. any problems with the 6" and that much weight? or should i stick with the 3"
    thanks
  2. Mar 11, 2012 at 7:18 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    Most 6" lifts come with a block and/or add-a-leaf for the rear lift. This won't fair well over time while towing.....you'll probably get some major sag in the rear. Alot of guys eventually swap the blocks/add-a-leaf out for a full leaf pack.
  3. Mar 11, 2012 at 8:21 AM
    Jmoney317
    Knoxville TN
    10 Tacoma
    so youre saying go with the leaf pack in the first place and i should be fine? or are there other problems (power, tire size, etc.) to consider about the 6"?
  4. Mar 11, 2012 at 8:44 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    the lift doesnt matter as much as tire size, on stock gears with 35's i dont believe my truck would tow a 4500lb boat very well
  5. Mar 11, 2012 at 9:27 AM
    Jmoney317
    Knoxville TN
    10 Tacoma
    im debating between 3" on 32's or 6" on 33's i know 33's will decrease the power but will it decrease it to the point that it would strain the truck or possibly break something?
  6. Mar 11, 2012 at 9:37 AM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    If money wasn't a big deal I would get a 6in lift 35s a new leaf pack in the rear or air bags, and most importantly you will have to regear your diff. I absolutely love the look of the 35s With the 6in but it's not cheap. if you can afford it then do it. If your towing something that heavy you would probably want to regear with 33s as well in my opinion. Mostly for the low end power for pulling it out of the water without trouble
  7. Mar 11, 2012 at 9:55 AM
    Jmoney317
    Knoxville TN
    10 Tacoma
    how bad will the gas mileage be if i regear?
  8. Mar 11, 2012 at 10:19 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    06 Dodge Ram - mine, 16 T4R - wife's, 11 Taco - totalled
    BAMF LCA Skids, ATO IFS Skid, OME 3" with 885 coils, tow package w/brake controller, 31" hankook dynapro atm, custom pin striping, tie down points in bed, custom trailer damage, big ass dodge type towing mirrors
    depends on the gearing you put in. stock on our trucks is 3.73. my last car had 4.70 gearing, but it was also a car designed for acceleration. you will probably lose about 2 mpg to get that much lift, the 33s and regear.
    i personally have a trailer that is 2600 lbs empty that my wife pulls. when it is loaded, i am guessing it weighs about 4000 lbs. the horse is pretty heavy (1200 lbs) and when he moves in the trailer, we feel it in the truck. if your boat/trailer is really 4500 lbs, i would be surprised. my boss has about a 26' bayliner and he said it weighs something like 3500 lbs. also, if you really need more torque when pulling the boat out of the water, you can put it in 4low.
  9. Mar 11, 2012 at 10:34 AM
    Cowboyz
    Cowboyz Membor
    Luke
    07 DC LB TRD Sport
    It's a wake boarding boat so he has a tower. It probably does weigh that much.
    Well if you have 33s and regear you will probably loose gas mileage (probably 2mpg). But your lifting your truck and putting a heavier tire/wheel combo. Your going to loose mpg no matter what you do. I was just saying you would want to get your stock power back after lifting and a regear would do that.
  10. Mar 11, 2012 at 10:39 AM
    Cowboyz
    Cowboyz Membor
    Luke
    07 DC LB TRD Sport
  11. Mar 11, 2012 at 12:14 PM
    Jmoney317
    Knoxville TN
    10 Tacoma
    rear air bags would be a good idea, i didnt really think of that. im ont worried about the power really, just the possiblility of breaking or straining something. i have ballast bags and ive pulled it out of the water in 2wd before with no problem forgetting that they were full (an extra 1200lbs) so 5500lbs+ with the bags full
    boat weight is 3300lbs, boat and trailer 4150lbs plus gear thats where im guessing 4500 + or - your boss might be talking just boat weight
    like i said i think there will be a power loss but not too dramatic as long as the strain wont break anything im happy
    thanks for all the info
  12. Mar 11, 2012 at 11:16 PM
    Cowboyz
    Cowboyz Membor
    Luke
    07 DC LB TRD Sport
    If your worried about power then lift it and regear it. That's honestly your best answer next to a supercharger
  13. Mar 11, 2012 at 11:18 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    x2
  14. Mar 12, 2012 at 6:37 AM
    Jmoney317
    Knoxville TN
    10 Tacoma
    Sorry, should be NOT instead of ONT
    When I read it again looks like only
    Not worried about power, only worried about breaking something from stress
    Sorry for the mixup
    Supercharged would be nice but way down the road, too much $$$$
  15. Mar 12, 2012 at 6:48 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    nevermind towing, just get a 3" lift. too many downsides to a 6" lift anyway. also someone mentioned airbags... they may work with modification with a 3" lift but no way with 6" lift, and i highly recommend them for towing
  16. Mar 12, 2012 at 9:43 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    If you want to tow successfully, leave it STOCK, if not, match new gears with new tire size and it gets expensive FAST.
    And if you build a new spring pack with 6" more arch, it might be awfully stiff for daily driving.
    Howard
  17. Mar 13, 2012 at 10:05 PM
    dreamnz
    dreamnz Well-Known Member
    SoCal
    PreRunner
    Suspension: Camburg Spindles, Bilstein 5100s, Deaver Leafs, BFGs Audio: IDQ 10 in "Marv" box - Hybrid Audio L6 mid bass/ L4 mids / L1 ProSE tweets - RF Power / Arc Amps...BitOne.1 to control it all.
    I've got 33s, stock gearing, and I tow a travel trailer that I figure ends up around 5k lbs loaded. It works, but feels very heavy. I need to regear pretty badly. It works for now though.
    I put +3 Deaver 10pack leafs in the back last year. I had them done custom to inlcude the load leafs (they don't usually have load leafs on a 10pack). Anyways, rode great, looks great, but still sagged badly with the trailer. I've got airbags now.
    So...my recommendations would be to plan on the regear and airbags if you lift it. (maybe airbags even if you don't lift) Of course it gets expensive, but is certainly doable.
    Also, look at the way the airbags mount when choosing a rear lift. I had to do some modifications to the mounting hardware to get the airbags to work with my setup.
  18. Mar 13, 2012 at 10:15 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I'd say go a 33 or 32 on 3".
