3" or 6" Suspension Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by killerkid2787, Aug 8, 2012.
  1. Aug 8, 2012 at 2:51 PM
    killerkid2787
    killerkid2787 [OP] Member
    Joshua
    2012 TRD Sport
    AirAid Cold Air Intake, WeatherTech Floorliners, WeatherTech Window Deflectors
    Im looking at getting a lift for my tacoma and i was just wondering your thoughts about some of the lifts everyone has out there. Im just starting to look so any of your experience helps.
    I am looking to lift for looks and driveablity i am not going to be in the woods much.
    i have a 2012 tacoma trd sport double cab long bed
  2. Aug 8, 2012 at 2:53 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Do a search on here and you will find tons of good info!;) Personally I would go with a 3" cause I think they look better but with your being a long bed, a 6" wouldnt look bad neither. Oh and how fat is your wallet?...that will be the biggest issue.
  3. Aug 8, 2012 at 2:57 PM
    killerkid2787
    Joshua
    2012 TRD Sport
    I really dont have a lot of money to through around but i dont want junk either.
  4. Aug 8, 2012 at 3:00 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay I would say go with a 3" kit then cause to go 6"...it will cost you easily over $1K for a basic kit. But since you dont want junk like a spacer lift, a 3" suspension lift can get a tad pricey too. Check out toyteclifts.com and check out there stuff and you can get a better idea on prices.
  5. Aug 8, 2012 at 3:14 PM
    Olson
    Olson Well-Known Member
    Eric
    Queen Creek, AZ
    4x4 DBL Cab TRD Sport short bed
    Front-3" Pro-Comp lift coils with ES6000 shocks Rear- 1.5" AAL with Pro-Comp ES9000 K&N Intake Blacked out headlights 8k HID Headlights 8k HID Foglights Cobra CB Radio Avid Off-Road Side steps 2 Memphis Amps 2 10" JL Subs(replaced stock) 3' Whip antenna Black Plast-Dip Valence
    3" is where its at. I have a 2011 TRD Sport Double Cab 4x4 4.0V6 with a pro-comp 3" suspension lift with 31.8" BFG A/T i still get 21ish mpg on highway going 68mph, and it does amazing offroad along with steering doesnt change still like stock. My friend in batallion has 6" lift. for it to look good you would need minimum 33" tires if not 35". You will not see anything over 17mpg on highway and 14 city if that. I mean it looks sick but for conventional use go with 3" you wont regret it.
  6. Aug 8, 2012 at 3:30 PM
    clfriday12
    clfriday12 Active Member
    Cameron
    NC
    Lifted
  7. Aug 8, 2012 at 3:31 PM
    killerkid2787
    Joshua
    2012 TRD Sport
    so with 32" tires did you have to trim anything?
  8. Aug 8, 2012 at 3:35 PM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    just from research I've done and different threads on tires and lifts, with 32's you'll need to do some trimming. 33's will require a lot of trimming and a possible cab mount chop. Others will chime in with more info though.
  9. Aug 8, 2012 at 3:35 PM
    Manwithoutaplan
    ID
    Go with a preformance 3 inch, 6 inch lift is useless you dont gain any travel and then you have to chop a cross member if you are 4x4. This is coming From someone who has the DB lift. YOu can stuff 35 if you get fenders on 3 inch.
  10. Aug 8, 2012 at 4:32 PM
    Blkvulcan
    Blkvulcan Well-Known Member
    Paul
    Augusta, GA
    12 Prerunner SR5
    If you don't have 4x4 you could always go with a 4" spindle lift.
  11. Aug 8, 2012 at 4:36 PM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    3 inch ftw!!! ICON!
  12. Aug 8, 2012 at 4:38 PM
    bridgcat
    Alabama
    When I was at stock height I had the same tires I have no. 265/75R16 which is essentially a 32" tire. All I had to do was take the front flaps on and then....never rubbed again!
  13. Aug 8, 2012 at 5:04 PM
    Manwithoutaplan
    ID
    agree.
  14. Aug 8, 2012 at 5:38 PM
    killerkid2787
    Joshua
    2012 TRD Sport
    bridgcat what type of steps do you have i like the look
  15. Aug 8, 2012 at 5:48 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    RCD makes a great 4.5" lift and is reasonably priced. If your looking into a DB lift and do not want to go 6", but higher than 3", it's a good option
  16. Aug 8, 2012 at 5:56 PM
    Manwithoutaplan
    ID
    Do you have to cut anything with the 4.5 lift??
  17. Aug 8, 2012 at 6:24 PM
    bridgcat
    Alabama
    They are N-Fab. Very popular among tw folks. I love 'em!
  18. Aug 8, 2012 at 6:26 PM
    bridgcat
    Alabama
    Yup...gotta cut the cross member.
  19. Aug 8, 2012 at 6:28 PM
    Tacoma343
    Tacoma343 Well-Known Member
    Jesse
    La Quinta, Ca
    2016 Taco White TRD Sport DCLB W
    Soon! 1 month!
    How do you like your pro comp lift... I've heard mixed reviews and am thinking of doing pro comp... I've heard it's stiff? Your thoughts?
  20. Aug 9, 2012 at 10:31 AM
    Olson
    Eric
    Queen Creek, AZ
    I love it. I mean it is stiffer than stock but it is a truck. It still rides nice and when i take it off road it does a damn good job. It is fantastic. When it comes time for replacing them i will keep pro comp however i will get the mx shocks vs the es series i currently have bc the mx are little more heavy dut. Over very happy with it
