3" or 6" Suspension Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by killerkid2787, Aug 8, 2012.
  1. Aug 9, 2012 at 12:46 PM
    Tacoma343
    Tacoma343 Well-Known Member
    Jesse
    La Quinta, Ca
    2016 Taco White TRD Sport DCLB W
    Soon! 1 month!
    Where'd you buy the lift at and who installed it? I'd like to do it myself if possible!
  2. Aug 9, 2012 at 10:58 PM
    Turd Herding Jim
    Turd Herding Jim What's wrong bro, DERPes flaring up?
    Big Jim
    Everett, WA
    07 SR5 4x4
    3" Icon Stage 3 lift, All Pro Off Road APEX front bumper, Amor Tech Off Road high clearance rear bumer, Armor Tech Off Road rock sliders. URD Short Shifter, HID Headlights, Level 8 Guardian Wheels, 285/75-16 Falken Rock Mountain ATS tires, 4.56's with front and rear ARB air lockers, BesTop Soft Cover
    +1, save your money and get the ICON 3", far better product and actually improves ride quality, until you actually adjust to 3" then a good bump and highway speeds may rattle your fillings out. But if you stick with 32" tires and not 33's then you wont need to set it where I have mine to avoid any rubbing or the CMC(cab mount chop). And look at it this way, if you're not going to wheel too much then there is no need for you to get the UCA's...
    Don't buy anything from 4wheelSHARTS, chances are you wont even get the right part you ordered the 1st, 2nd or even 3rd try
  3. Aug 10, 2012 at 7:30 AM
    Olson
    Olson Well-Known Member
    Eric
    Queen Creek, AZ
    4x4 DBL Cab TRD Sport short bed
    Front-3" Pro-Comp lift coils with ES6000 shocks Rear- 1.5" AAL with Pro-Comp ES9000 K&N Intake Blacked out headlights 8k HID Headlights 8k HID Foglights Cobra CB Radio Avid Off-Road Side steps 2 Memphis Amps 2 10" JL Subs(replaced stock) 3' Whip antenna Black Plast-Dip Valence
    I bought mine from 4wheel parts however i went to store in thousande oaks and they love miltary so they hooked me up i got suspension, 5 32" bfg a/t, cold air intake, and it was all installed for roughly 1800. I had a good experience. But not every place is the same.
  4. Aug 10, 2012 at 8:41 AM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    you are a lucky one! I've tried ordering from them in the past and had to return items over and over because they would constantly send the wrong freaking parts.
  5. Aug 10, 2012 at 8:43 AM
    killerkid2787
    killerkid2787 [OP] Member
    Joshua
    2012 TRD Sport
    AirAid Cold Air Intake, WeatherTech Floorliners, WeatherTech Window Deflectors
    I have had bad luck with 4 wheel parts also thanx for all the info I'm going to look up the ic on lift
  6. Aug 10, 2012 at 8:46 AM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    she's pricey, but it drops panties haha...not really MOST women don't really care, "something 'bout a truck"
  7. Aug 10, 2012 at 8:52 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    If you are just goin for looks then get the full 6". 2012s look dam good with a 6". Its pretgy procey however. Just a hair under 2g I believe
  8. Aug 10, 2012 at 4:54 PM
    killerkid2787
    Joshua
    2012 TRD Sport
    i just talked to a guy about some new pro comp pro runners has any one out there had any experience with these shock absorbers? they sound great but anyone that is good at selling can make something sound good!!!!!
  9. Aug 10, 2012 at 4:55 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    pro comps ride stiff in general
  10. Aug 10, 2012 at 5:07 PM
    killerkid2787
    Joshua
    2012 TRD Sport
    i am also having a hard time finding a cat back exhaust for my dclb does anyone know of a good set up?
